Dash Vents
Dash Vents
I am working on a '70 442 Sports Coupe (Post Coupe) The instrument panel has no vents of any kind. The car has only the floor vents. I have never seen this arrangement before. it looks a little odd if you ask me. Is this unique to the coupes? The dash vents must have been a seperate option. How difficult would it be to chamge out to a vent style dash? Can someone enlighten me on all of this?
Randy
Randy
Yes - it's unique to the NON-AC post coupes. A non-AC regular hardtop would have end vents in the dash and a filler plate in the top/center of the pad instead of your "smoothy" pad.
Dash vents weren't "optional" to my knowledge on the post coupes (without AC). Of course, with AC, the post coupes got the "regular" dashpad with end vents and the center vent.
And...the "smoothy" dashpad does look a bit odd at times but after seeing thousands of them with end vents and a center vent the mind gets biased a bit and used to seeing that.
Just think of it as a "cleaner design".
The cool part about the wing/vent windows is how they hit the sport mirror body when opened up.
Then why do 64-69 hardtops (non AC) have side vent windows AND dash panel vents? That's why I was thinking it's not logical. I can accept what you say about why there were no vents in the 70-72 post coupes without AC, but I still don't see the 'logic'. Did 70-72 Cutlass Town Sedans (with vent side windows of course) or non AC Vista Cruisers have dash vents? I think so
1970- 72 non AC VC's do not have dash vents. Same dashpad as the post coupe. 1969 was the first year for the "flow through ventilation". That is why they have the black vents in the door jamb on hard tops and convertibles but not on A bodies with vent windows 1969 to 72.
Hmmmm, come to think of it our 67 Cutlass Town sedan didn't have vents on the dash. It had wing windows and a lower pull vent for outside dust, I mean air.
But that still doesn't address the 68/69 non AC cars. Did they have dash vents for non AC? Sorry if this sounds like beating a rented mule, but I'd really like to know the answers and there's only one way to find out - ask.
![Big Grin](https://classicoldsmobile.com/forums/images/smilies/biggrin.gif)
I really don't know what to say about 64-69. I stumbled into the thing about the vent wings because I wondered why my Camino didn't have dash vents and the cars did. It was so long ago I don't remember where I came across the info. I think there is a version for a car without wing vents and without AC that has the side vents but no hole for a center vent.
It may sound like beating the rented mule, but it's good stuff to know if you're buying, selling or swapping parts. Throw in another little twist. Do you need a dash with a display for a column shift auto or a blank for a 4-speed?
![](http://www.herbsparts.com/prodimages/large/316-D68KIT-1.jpg)
Product ID: 316-D68KIT
68-69 DART DASH BEZEL KIT NON-A/C
does this help anything? -------> http://www.ebay.com/itm/1964-65-CUTL...r#ht_500wt_922
Any post coupe,4-door sedan,wagon,or Vista,with no AC,got the ventless dashpad.All of these cars also had the wing windows.I like the ventless pads,and I have put some in hardtops,for a cleaner look.i found one in dark saddle,and I will be putting it in my 72 Supreme,along with my custom plastic section.It's gonna look slick.I promise.
You really do hate me don't you Allan.
(Kidding..) I was thinking about those door jam vents today and you just confirmed what I was thinking.
re: dash display for shift? Yes for column shift. On floor shift no. The display area would just be filled in with matching dash material. Here's a great example of one done by Ron Roth (who is an acknowledged expert on these dash restorations)
Mopar? Gotta compare Olds to Olds
[QUOTE=But that still doesn't address the 68/69 non AC cars. Did they have dash vents for non AC? Sorry if this sounds like beating a rented mule, but I'd really like to know the answers and there's only one way to find out - ask.[/QUOTE]
Allan,
The 1968 2 door hardtop and 1968/ 1969 2 door post coupes, non AC cars, do not have dash vents. 1969 2 door hardtops, non AC, have vents (they are different than the AC vents on the outside, and the center has a block off plate on the dashpad opening.) This model is without the vent windows and with the vents in the door jambs unlike the post coupes and 1968 2 door hardtop. I hope that makes sense.
Allan,
Well I think the picture is clearing up somewhat.
1964 - 1972 Post coupes/Non AC - wing window - no dash vents
1964 - 1972 Wagons/sedans/Non AC - wing window - no dash vents
68 HT coupe - Non AC - wing window - no dash vents
69 -72 HT coupes - Non AC - no wing window - side dash vents/blocked off center vent.
All 64 - 72 everything with AC has dash vents.
Is this about right?
Oh gosh no! I didn't take it in a bad way at all. I was just trying to mess with you because you expanded the question to include other years that I didn't have an answer to. All in fun and I might even mess with you again. Meanwhile what did you come up with?
I see a pattern forming here. I think you might be on to something! This complicated dilemma may be on the verge of being solved by your ******* the issue with your sleuthing talents.
I also said I might mess with you some more.
![Stick Out Tongue](https://classicoldsmobile.com/forums/images/smilies/tongue.gif)
Dang, I'm glad Allan is a great guy with a good sense of humor!
Sometimes I don't see things when they are hiding in plain sight...glad I was able to give you an opportunity to 'vent' ![Big Grin](https://classicoldsmobile.com/forums/images/smilies/biggrin.gif)
Learn something new all the time. Thanks for your patience.
