dash heater face plate
Old Jan 31, 2012 | 08:10 PM
centonze's Avatar
anyone ever try to paint the dash heater face plate on 69 442. If so what paint and prep did you use?
Thanks, any info is helpful.
Old Jan 31, 2012 | 11:24 PM
garys 68's Avatar
Are you trying to get it looking original?
Old Feb 1, 2012 | 04:42 PM
centonze's Avatar
Yes original
Old Feb 1, 2012 | 08:30 PM
70Post's Avatar
Is it metal or plastic?
Post a good up close detailed pic.
Old Feb 2, 2012 | 10:00 AM
garys 68's Avatar
I repainted mine in black, but I also had to put new lettering on it.
If you want it restored, why not just buy a new faceplate?
http://www.yearone.com/serverfiles/f...ain2.asp?cat=3
Old Feb 2, 2012 | 10:23 AM
70Post's Avatar
Year One part number for that??
Old Feb 2, 2012 | 03:16 PM
centonze's Avatar
Year one did not have 1969. They had 70.
Old Feb 2, 2012 | 03:20 PM
centonze's Avatar
The face plate is chrome with raised letters. It was originally black
Old Feb 2, 2012 | 09:43 PM
70Post's Avatar
Post a good pic. IS IT METAL OR PLASTIC??
I'm assuming it's metal. If so, you should be able to remove the old paint with lacquer thinner, etc. If it's a grained/textured chrome surface then it'll take a bit longer to remove it all.
Get it CLEAN and then figure out what black paint it should have...satin, semigloss, etc. You can spray the whole thing and then carefully wipe the tops of the letters with a THIN cloth held tightly over a finger to remove the paint from the letter tops. You can mask off any raised border with tape as well to save you the trouble of wiping the paint off of that part.
Do any chrome "polishing/cleaning" on the border and letters before you paint it. You can go back and wipe off smudges, etc later but once you paint it you don't want to be doing any heavy duty chrome cleaning next to your new paint surface. If you use a chrome polish of any sort then make sure you clean off the to-be-painted chrome areas well with a wax and grease remover, etc (you can just scrub the whole thing with soap and water if it's removed from the car)...you don't want any chrome cleaner residues affecting the paint adhesion.
Obviously, you will need to remove or mask off any parts that you don't want any paint to get on such as any plastic lenses that show through the faceplate, etc....that's why I've asked for a pic!!
Old Feb 3, 2012 | 08:43 AM
centonze's Avatar
Thanks for the advice. It sounds like the best way to do it.
olds3442
Mar 1, 2014 03:59 PM
Oldssupreme
Mar 12, 2013 10:56 PM
RandyS
Jul 18, 2012 04:00 PM
oldspackrat
Nov 23, 2011 08:19 AM
archerbob
Sep 11, 2011 06:46 PM
