Convertible Door Windlace Question
Old Jan 1, 2013 | 09:43 PM
costpenn's Avatar
Bought the repo door Windlace set for te 72 vert I'm doing. The new pieces did not have the cut out for the door jamb wedges, and I didn't do a good job cutting them out myself. Does anyone have any tips on this? The angle, and different materials make it a challenge to do without messing up the rest of the piece.
Old Jan 2, 2013 | 03:50 AM
fjross's Avatar
Sharp pair of wire cutters for the small two cuts and I used several razor blades in a utility knife and kept scoring the long cut out until it was able to be flexed back and forth until broken. Add pearl white interior to this for toppers.
Dave
Old Jan 2, 2013 | 07:20 AM
Pacecar's Avatar
Yes I had to go thru the same procedure. When cutting out the rectangle, also just be careful in the horizontal cuts. Don't go too deep or you will cut into the groove that holds it in place. The interior metal "mesh" pieces have to be cut with a utility knife. lots of work
CovertCutlass
Mar 29, 2014 11:18 AM
dnmfranco
Oct 29, 2013 12:41 PM
507OLDS
Aug 22, 2013 07:40 AM
olddaz
Aug 18, 2013 08:44 PM
507OLDS
Oct 28, 2010 08:23 PM
