Cigarette Lighter issues
Old Feb 7, 2018 | 07:43 AM
MyBlue72's Avatar
I need to ask a dumb question..........
I don't smoke but still want the lighter in my 72 Cutlass to function properly. My old lighter and housing had rust in/on them both, so I bought another cleaner looking set from a member here.
When I push in the lighter it does not lock into position. No springy type action like it should have. So my dumb question is............is it the housing that is not functioning, or is it the lighter itself that is supposed to have the spring type action?
This is two lighter now that didnt work for me. Is there a way to fix this issue?
Thanks,
Doug
Old Feb 7, 2018 | 08:04 AM
oldspackrat's Avatar
Fundamentals first, did you check for 12v at the orange wire that attaches to the back of the lighter socket? If so, make sure you have a good ground. If both of those are ok, it is likely the element itself. I'm not sure exactly how the element locks into place but they are not complicated.
Old Feb 7, 2018 | 08:20 AM
MyBlue72's Avatar
I do know there is power to it. When I pushed it in yesterday it blew out a few sparks and blew the fuse at the fuse box. It just doesnt have that springy/lock in place function going on. I guess I will have to bite the bullet and buy a new repro set.
Thank you.
Old Feb 7, 2018 | 08:29 AM
You have a bad element if it shorted, blew the fuse, and won't stay engaged. If I remember right, the element cartridge unscrews from the handle so it can be replaced.
Old Feb 7, 2018 | 08:31 AM
MyBlue72's Avatar
Eric,
Thank you so much. Greatly appreciated. I will try to find and element.
Have a great week.
-Doug-
Old Feb 7, 2018 | 11:16 AM
frankr442's Avatar
Two companies made elements and housings, Casco and Rochester I believe. Make sure you're not trying to put one into the other, I don't think they interchange.
Don't smoke either so I'm not totally up on lighter parts.
Old Feb 7, 2018 | 11:29 AM
dalilama's Avatar
I have one of these out of a '72 that works fine. Let me know if you are interested and I'll send pictures.
Old Feb 7, 2018 | 11:43 AM
MyBlue72's Avatar
On a
Thanks All. I just ordered a new one this morning from The Parts Place. Wish me luck.
Old Feb 23, 2018 | 04:26 PM
abrasv's Avatar
If that would fit in a 69 I might be interested. How much for it?
Old Feb 23, 2018 | 05:33 PM
Yellowstatue's Avatar
The socket has two wide ears at the bottom which grip the round edge of the element when it is pushed in, and as the element heats up the ears expand and release the element. Rocket Science!
Old Feb 24, 2018 | 01:34 PM
dalilama's Avatar
Not sure if it will fit. I was selling for $20 plus shipping. Here are some pix if you find out it does:
Old Feb 24, 2018 | 04:29 PM
abrasv's Avatar
Looks like it might fit and not quite as bad as my current one. Pretty close though
How much?
Old Feb 25, 2018 | 02:55 PM
dalilama's Avatar
How much?
Per the note above, $20 plus shipping. If you'd like it PM me with with your zip code and I can check the shipping rate.
Old Feb 25, 2018 | 03:40 PM
tru-blue 442's Avatar
Old School Olds
Looks to be 70-72.
Old Feb 28, 2018 | 06:56 AM
abrasv's Avatar
Thanks.
I've decided to not replace the lighter but to put a 12 volt power supply socket that I ca plug in to.
Old Feb 28, 2018 | 07:31 AM
Others have done the same with a USB type.
Old Feb 28, 2018 | 08:31 AM
If you install a USB adapter, be sure to use a high quality one. Chris Witt almost burned his car down when a cheapie shorted out on him.
Old Feb 28, 2018 | 08:50 AM
dalilama's Avatar
Thanks.
No worries - good idea about the socket.
brown7373
Jun 30, 2016 07:42 PM
Beob
Mar 5, 2011 01:45 PM
Phil Glass
Oct 25, 2010 11:20 AM
tim72
Aug 5, 2010 07:51 AM
Bunser
May 24, 2010 05:47 PM
