carpet help
Old May 6, 2009 | 08:26 AM
Danielle's 71's Avatar
ya'll come back now....
carpet help
i cant seem to find any carpet to fit a cutlass seperme so will cutlass carpet work if its the same year and number of doors?
Old May 6, 2009 | 08:32 AM
Operation Deltapower's Avatar
may the Olds be with you
i would think so. the only thing that i would think might make a difference is floor shift vs. column.
Old May 6, 2009 | 10:09 AM
wmachine's Avatar
Trying to remember member
Hey, Danielle, you're no longer a Newbie! Spread your wings and post in the main sections now!
Old May 6, 2009 | 10:13 AM
i know but its so easy to post in here...haha...but by any chance do you know the answer to my qusetion?
Old May 6, 2009 | 10:22 AM
The reason for posting in a different section is us lazy mods don't want to have to move your carpet question to the interior section. It will also help you out when you use the search fuction to help find other information.
Old May 6, 2009 | 10:32 AM
bccan's Avatar
I think you will find the carpet is pretty much a generic "A" body item & will fit all 2 door/Conv "A" bodies of the proper era. Order by color. You will have to trim and/or punch holes where necessary for floor shift, console brkts, seat mounts, etc. Start w/ rear section, work from middle out, use trim adhesive after final locating & trimming if you choose to-helps keep it from possibly shifting.
Old May 6, 2009 | 10:48 AM
so a 1970 cutlass sepereme will fit a 1970 cutlass carpet?
Old May 7, 2009 | 02:08 AM
Bluevista's Avatar
Registered
Yes, the Cutlass and Cutlass Supreme are the same, the only difference is if the car has a 4 speed according to the carpet place, the 2 and 4 doors are different of course.
Auto Custom Carpets makes just about all of it for everybody it seems? It's usually drop-shipped from them when you order it.
They have another site they sort of discreetly sell carpet on called Auto Carpet Originals, much better prices.
http://www.autocarpetoriginals.com/i...=1970+cutlass+
Old May 7, 2009 | 05:50 AM
68Tom's Avatar
Honestly, aside from the difference between 2-door and 4-door, automatic or manual, I'm pretty sure carpet manufacturers simply make the same carpet for all GM A-bodies for 68-72. Hence, why the 4-speed carpet for a '68 442 fits like complete sh*t. The hump on the 442 for that year is much lower than a Chevelle, and hence, does not lay right. You have to buy the automatic trans carpet instead.
Old May 7, 2009 | 12:41 PM
You are correct. All 1968-1972 2dr Cutlii (Supremes, 442s, F-85s) all use the same carpet.
milesmonte
Mar 23, 2015 07:31 AM
STLCRZY
Apr 15, 2012 10:29 PM
STLCRZY
Apr 15, 2012 01:18 PM
cobalt
Mar 6, 2012 12:12 PM
cobalt
Feb 21, 2012 03:39 PM
