Attaching the dash bead on a 70 442 W30
Old Sep 9, 2019 | 03:02 PM
sevntyW30auto's Avatar
I have the above and need to attach it to the dash without the clips found in later year cars. I can't bring myself to putting holes in a perfect dash. Any good ideas on an adhesive to use?
Lawrence
Old Sep 9, 2019 | 03:20 PM
vette442's Avatar
1970s did not use the punch in clips and did use an adhesive. I'm sure someone will recommend something from 3M or similar. I will also need to do this to my '70 SX as the old adhesive is shot on the bead.
Terry
Old Sep 9, 2019 | 06:16 PM
jensenracing77's Avatar
The original 70 bead was solid and glued on a little easier because the slit was not there to reduce the surface area for the glue to hold. I looked and fought this for a long time on the W-30 I built and ended up having to poke the holes. The only thing I could come up with was to fill the bead with some kind of flexible filler and sand the back side flat for that extra surface area. I decided not to try it thinking I would end up messing up the molding and it still not hold. There is a reason it was one year only. In the end I think you will have to poke the holes also.
Old Sep 9, 2019 | 07:30 PM
Jensenracing 77 I know what you are talking about and thought how am I going to get this bead to hold. Man I hate to poke the holes.
Is yours still holding? How long has it been installed?
Old Sep 10, 2019 | 02:26 AM
I ended up selling the car but I am sure it is still holding. Those little clips are tough and hold tight.
Vader
Nov 6, 2018 10:39 AM
Vader
Jun 9, 2014 08:07 AM
DENT
Nov 17, 2012 05:02 PM
bobb
Jan 16, 2012 06:52 AM
70442holidaycoupe
May 12, 2008 10:30 AM
