arm rest base help
arm rest base help
69 olds convert, arm rest bases - i just painted them w/ a paint supposedly for plastic and did not adhere well. i cleaned w/ soap/water prior and mineral spirits and let dry before spraying. paint was supposedly for plastic (local hardware store paint).
any ideas for cleaning up and redoing. where can i get correct Parchment paint.
if not, what is diff between arm rest bases. i looked for repo replacements and all say not for convert. My pad measures 11.5" so it should fit ones listed by OPG/Year One, etc. Is there another diff for converts. (screw holes/shape?).
thank you
thank you
I used dish soap, SEM soap and then wax and grease remover, then Bulldog adhesion promoter then SEM spray paint. They came out great and no peeling so far.
I did all my plastic interior parts with SEM paint, I'm sure they have a parchment color.
https://classicoldsmobile.com/forums...-projects.html
You are better off using your originals if the plastic is in good shape....just reshoot them using the procedure already discussed.
That, or find some nice used originals and paint them (but it's hard to find decent used bases in the lighter colors...typically VERY deteriorated). The repro bases would be my LAST choice.....they don't seem to fit very well.
As far as colors....you could take a look at SEM's Super White color. Despite it's name, it's not a pure or bright white....slightly off white.
Also....adhesion promoter should still be the next step after cleaning and prior to color spraying.
RandyS
June 20th, 2012 12:29 PM
