72 Delta 88 interior
I have a 72 Delta 88 that has white seats/door panels but the dash and carpet is a very dark shade of green. I was wondering if anyone knew the actual name of this color. Someone said it might be midnight neutral?
Also would anyone know where I might be able to find the correct floor mats?
Thanks in advance.
Thanks in advance.
Post a photo of the body cowl tag. It's often found on the firewall on the driver's side under the hood, although I'm not sure about this on the full-size cars. On my '73 Custom Cruiser, it's located on the passenger side under the rear edge of the hood. This will have codes on it that might tell us what the interior color is.
Although this is for a '73, it looks like this:
Thanks Jaunty75, that '72 is on the east coast so I won't be able to check out the cowl tag until I get back there in November.
Now with that '73 Omega I purchased in CA that you noticed, I have an Olds on each coast.
Do you know of a web site that has the decoder for the cowl tag?
I know of only this site:
http://datatagdecoder.com/_beta/form.html
Unfortunately, it works only through 1972, so it would help with your Delta 88, but not with your Omega.
