72 Cutlass Lens Armrest Courtesy Light White
Has anyone bought these? Are they worth it? Also, what # light goes in these sockets? Thanks
http://www.ebay.com/itm/OPGI-Lens-Ar...#ht_1385wt_995
Are they worth it? You mean instead of no lenses? If you need them I think they are pretty close to the originals and work fine?
I don't remember the bulb off hand, but it should be in your owners or Service Manual.
I bought some repro lenses from bap - looked ok but did not snap in correctly. Prolly the same as thse from same maker. Typical repro part. They worked good enough though.
Bulb is a #90 - double contact bayonet base. IF you use a single contact bulb (like what most stores try to sell you) the fuse will blow instantly.
