71 Sienna Interior Dye Match
It took a few tries,and some mods to the color & the gloss level,but I got it nailed.The camera flash makes this look glossy,but it is not.
I will be working on the 70 blue next,then on to the others.
This is going into a 71 442 convertible,sienna in & out.It is an exceptional car,and I need this right.I have all of the 4-spd stuff rebuilt & replated as well.
I have the correct mix for the 72 dark saddle,as that is what is in my 72 supreme.I have a few others as well,and I will continue to get the others as I get the opportunity.Unless it is black,non of the rattle cans from the catalog companies will match the way they should.
I spray these out of a spray bomb,with the glass jar.You could take this same can of mix,load it into an aerosol can,and it will come out different.I learned that when doing the dark saddle.Even the gloss level will have a significant effect on the color.
The 70 colors should be interesting because a lot of them have metallic in them,so that will be another variable in the equation.
I realize this is an older thread, but where did you locate the sienna interior paint? I recently picked up a hub for the Olds sport wheel, and would like to paint it to match the steering column. Thanks.
Hurst/Olds 73/74
October 23rd, 2012 06:30 AM
leadfoot067
January 6th, 2011 04:55 AM
