69 bucket seats and shifter questions
Traded for a 69 Cutlass Conv that someone did a H/O Tribute(black w/ gold). They did a good job on Tribute outside but not much inside, Bench seat solid but cracking, springs a little weak on edge. back seat good but plan to redo also, called local highly recommended shop to have them freshened up. However I found a 69 with buckets thats be parted out. Should I go with the buckets and if so what do i do for a shifter, ive seem them for 800-900 bucks but im not sure its the right one. if I go with the buckets, then I need floor mounts from repro shop ? is this a big job ? what shifter ? cutlass was a hinged console ? H/O looks like a dual gate with a small cover ? is this only out of a 69 H/O ? I know this is only a Tribute car, I could have never afforded it if it wasnt, but I do want to do whats close to right but function is more important. I can post pictures if it helps. Thanks for any help.
The H/O shorty consol is a POS. I lined mine with fiberglass to give it some beef.
Changing from bench to bucket is a big job. Just don't forget the seat tracks are different.
Gottcha
You can get the repo shorty consol [like the one I lined w/ fiberglass because it is flimsey] and get a Olds Dual gate off of e-bay. You need to change out the speedometer if it hasn't been done yet.
Hey 69OLDSCUTCONV,
Would you mind sharing a picture of the shifter that is in your car. I am going to buckets and trying to decide on a stock look or aftermarket. I would be interested to see what your setup looks like.
I switched from bench to buckets on my Chevelle and am doing the same on my Cutlass. They make a very cheap 2 piece set of inner brackets that will work but the best are the ones repop'd by Goodmark. It is a 4 piece set. The inner pieces each have two studs and the outers are a single stud that mounts over the threaded hole in the pan. All 4 need to be welded into place. Once you get past pulling out all the carpet, its not a bad project.
Here are photos of the cheap set, the repop and a pair drilled from a A-Body donor.
mark77301
October 26th, 2019 06:23 PM
oldspackrat
April 30th, 2013 08:08 PM
gearheads78
March 19th, 2012 07:42 AM
1960es
September 4th, 2009 03:02 AM
