? '68 GTO tilt column (A-body same?)
I believe that the 68 Pontiac GTO column IS the same as a 68 442 and would be a direct swap. (floor shift & with tilt) (obviously the signal and tilt lever is prob. different but am assuming the Olds levers will swap out)
I'm looking for solid confirmation from someone that is Positive that the above is True... Or if it's not, then what the heck is different?
Thanks!!!
Thanks!!!
Thanks!!!
Thanks!!!
c-towndave
Suspension & Handling
Oct 21, 2013 07:41 AM
