68 Dash removal PITA
I am sure some of you guys have found this out, but removing the dash from a 68 442 is one heck of an adventure. I knew where the studs were located but even with that its a royal PITA. A must is to remove the instrument gauges which is most difficult to do. Took me almost an entire day to get it out and I did not break anything.
I will be taking mine out soon to convert to rally pack. I've been putting off as long as possible due to fear of damaging a perfectly good dash pad. Any help in locating studs, dos and don'ts confidence builders would be helpful. Thanks
https://classicoldsmobile.com/forums...-68-442-a.html
Like others have said, the gauges come out the front if you remove the two lower screws that hold the pod. I use a very thin butter or frosting knife to guide the gauges out. I also have a set of 1/4" drive sockets with a built in universal that work really well for getting into tight spaces
If you must remove the dash here's a thread that shows the location of the speed nuts and the center push-in stud.
https://classicoldsmobile.com/forums...rior-help.html
Gary, Mike,
I appreciate your patience in once again helping a guy through this process. Sharing your comments and experience makes the difference between a fun productive hobby and just another expensive, disappointing experience. In poring over the text you provided and pictures supplied in the threads I now think it's doable. All I need now is time, 1/4" socket set w/ extensions and universal joints and a grand kid. All easily obtainable. Thanks again
Dan
Dan
OK.... I am glad I found this post. On my '68 the center instrument cluster ( where the speedo is) has several issues: 1) right turn signal lamp, 2) bright light lamp, and 3) instrument lamps, only work occasionally, I pulled the bulbs (difficult to get to) and tested them and they are all fine. I can tell that the pins on the printed circuit board (PCB) are a little loose. I am confused from this post if I have to pull the dash to remove the instrument... or if I can pull it from the front... Can someone please clear up this issue for me? I have the factory assembly manual and wiring diagrams... but don't know how it was done from the factory (My guess is that the entire dash was installed as a unit). You need tiny hands (like a 5 year old) to get to this mess... and I am 6'2 / 250 ! Ha....
