67 cutlass rear side panels
Old Apr 3, 2015 | 02:22 PM
irkennedy's Avatar
Does anybody know if the 67 cutlass 2 door post car come with arm rest panels in the rear? I have door panels but they only cover the top half and the "specialist" said my car didn't come with arm rest panels only the convertible came with armrest panels
Old Apr 3, 2015 | 03:10 PM
Oldsmaniac's Avatar
Yes there are rear arm rest panels with ash trays and a filler at each end near the seat sides.
Old Apr 3, 2015 | 03:18 PM
irkennedy's Avatar
You are a life saver....Were they the same as the convertible? In other words, if I purchase the one for the convertible will it fit? No body seems to make them for my car
Old Apr 3, 2015 | 04:07 PM
Oldsmaniac's Avatar
I am not sure if they are the same for a vert. Where are you trying to purchase them from? Have you tried OPGI?
Old Apr 3, 2015 | 04:19 PM
irkennedy's Avatar
OPGI is who I have been on the phone with for the last 4 hrs & they didn't even know the car came with the rear armrest panels. They also said the vert panels won't fit and I can't find anyone who makes them. I think the vert panels will fit since no one sells them but OPGI said they wouldn't fit which is hard to believe since they didn't even know the car came with the panels. Any suggestions?
Old Apr 3, 2015 | 05:00 PM
Oldsmaniac's Avatar
I cant believe that nobody repros these, parts place? Yearone? I know from 64-67 they pretty much interchange but dontk now if a vert s different. Most likely pontiac chevelle interchange as well. Mine needed to be recovered and the upholstery repoped them as original.
Old Apr 3, 2015 | 05:04 PM
Run to Rund's Avatar
The 3807 panels fit the same as the 3617 (F85 deluxe hardtop); just be sure the color and pattern is correct if you order them from Legendary, etc.
Old Apr 4, 2015 | 06:10 AM
RonFX's Avatar
rear panels
Guys:
I am having the same problem locating new door panels. I have a 66 Cutlass 2 door post car. The rear seat goes full width, panel to panel, my 66 does not have the built in lower arm rests like R to R posted a pic of, I have tried quite a few pepop shops and No luck. The panels are full height instead of the shorties everyone sells, any help would be great.
Thanks, Ron
Old Apr 5, 2015 | 04:28 PM
irkennedy's Avatar
So far I haven't found anyone who makes them. Everyone keeps saying they are only made for convertibles
Old Apr 5, 2015 | 04:29 PM
irkennedy's Avatar
Thanks! I'll check them out
Old Apr 5, 2015 | 04:48 PM
Oldsmaniac's Avatar
The conv does have the rear courtesy lights in the armrest while the others use a dome light or the inside sail panel lamps. They dont use the armrest lamps.
Old Apr 6, 2015 | 06:46 AM
irkennedy's Avatar
I just called PUI and Fusick and nobody repros these products for a the 67 post coupe and when I bought the car they didn't have them in there. I'm waiting for Legendary to call me back
Old Apr 6, 2015 | 07:08 AM
lemoldsnut's Avatar
I have a full set of black interior door panels from a Cutlass. It is not a post car it is a hardtop but has the same style door panels that do not go up over the top edge of the door. They are black. I also have a rear set in the two tone cream color as pictured earlier in this thread in nice shape.
Contact me direct at lemoldsnut@aol.com
Larry Moyer
Redmond, Oregon
calls 8 am to 8 pm west coast time 541-815-4363
Old Apr 6, 2015 | 07:22 AM
irkennedy's Avatar
Larry Moyer
Redmond, Oregon
I need the bottom half of the rear panel aka the rear armrest panels. Do you have those?
Old Apr 6, 2015 | 07:24 AM
Oldsmaniac's Avatar
These should not be difficult to find used and they can be recovered as original.
Old Apr 6, 2015 | 07:26 AM
irkennedy's Avatar
Well this is my first time restoring a car and I don't know many people so if you can point me in the right direction that would be great. Thanks
Old Apr 6, 2015 | 07:33 AM
Oldsmaniac's Avatar
See what Lemoldsnut has and then post a wanted ad here in parts wanted. You can also check Ebay.
Old Apr 6, 2015 | 07:39 AM
lemoldsnut's Avatar
i can do rear arm rest panels. as long as not a convertible. Those are much wider to clear the top pistons.
Email me direct
lemoldsnut@aol.com
Larry Moyer
calls west coast time 8 am to 8 pm 541-815-4363
Olds442redberet
Jan 23, 2014 06:49 PM
eudaman
May 19, 2013 05:30 PM
62radarlove
May 16, 2012 10:15 PM
craftsman1956
May 13, 2011 07:37 PM
chris83
May 25, 2010 02:58 PM
