63 Starfire rear seat belt-where to mount?
Old Oct 19, 2021 | 03:24 PM
therobski's Avatar
See the dimples pictured with the gray tape in order to drill the holes for rear seat belt placement? In this instance, the shop manual is not very helpful. I want to measure 3 times and drill once as they say. I believe the anchors are under the carpet for the front. Does anybody know if this is correct where I have them placed? Thanks.
Old Oct 19, 2021 | 04:12 PM
Yellowstatue's Avatar
Perhaps there might be a dealer bulletin for installation for that era of car.
Old Oct 19, 2021 | 06:33 PM
rocketraider's Avatar
Oldsdruid
Look UNDER the car and see if there are weld nuts already in place for rear belts. If they're there and you can access them, drill thru from the bottom side. If not, drill a small pilot hole at the dimple before drilling the anchor bolt hole.
Use a large diameter THICK flat washer on both top and bottom of the floorpans to keep the anchor bolts from pulling thru. Improperly anchored belts are worse than no belt at all.
This is a job where caution is important as you don't want to drill into a brake line.
Old Oct 19, 2021 | 06:35 PM
Oldsdruid
Just a thought- look in ACCESSORIES section of the shop book and see if it says anything about installing rear seat belts.
Old Oct 20, 2021 | 07:15 AM
therobski's Avatar
Thanks Rocketraider Ill look up the shop manual later today..Ya never know right?
Old Oct 20, 2021 | 09:24 PM
Charlie Jones's Avatar
Phantom Phixer
The front has nuts and backing plates already installed . 7/16 fine thread , I believe .
There are dimples in the sheetmetal in the back . Where it is suggested that the holes be drilled .
You will need " large fender washers " there for backing plates .
I'm going to the shop tomorrow , and I will post some pics tomorrow evening of the locations .
Old Oct 21, 2021 | 03:48 AM
therobski's Avatar
Thanks Charlie!!!
Old Oct 21, 2021 | 07:21 PM
Phantom Phixer
OK , here are pics as promised ;
The front mountings are circled in red ;
There are six " dimples " under the rear seat . The red ones are for the outer seat belts .
The blue ones are for a center belt .
Here are some photos from the bottom . I don't think you will have any clearance problems .
And last is a shot of one of the front backup plates from the bottom .
Old Oct 21, 2021 | 08:42 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Big help Charlie. Rob and I will both appreciate that since I am his helper.
Old Oct 21, 2021 | 09:10 PM
Phantom Phixer
Rob is lucky to have a " Phantom Phixer " for a helper .
If you can fix a Phantom , you can fix anything .
Old Oct 22, 2021 | 02:45 AM
redoldsman's Avatar
Thanks Charlie. Rob and I haven't known each other very long but we are having a good time fixing odds and ends on this Starfire. Our biggest challenge has been the rear power windows.
Old Oct 22, 2021 | 07:27 AM
therobski's Avatar
Yes indeed thanks to both of you for help and kind words. Yes, replacing the rear power window motors was a challenge but we gotter done. The 58 year old shop manual was not much help with power windows only manual.Same with the rear seat belt option. Very fortunately the rear floor area as well with the rest of this car has very, very little surface rust ( zero rot) -makes it a lot easier. I have worked on and restored a few rust buckets, this is a nice example to try and keep it as original as possible. So thanks again for taking your time.
justintiime
Jun 13, 2021 07:07 PM
therobski
Oct 9, 2020 02:43 PM
cfair
Sep 10, 2020 11:47 AM
Kyle's77cutlass
May 22, 2019 06:31 PM
dennis_30281
Jan 14, 2019 03:07 PM
