1984 Delta 88 rear driver's side door panel
The tool I bought to remove the door panel did nothing but break the plastic snap-like buttons. Is there any way to replace them? The panel will be put on the original door.
Also, I bought a tool to remove the ring from the window handle. It fits real nice up under the handle and when turned around the base does not seem to be hooking onto anything.
![Confused](https://classicoldsmobile.com/forums/images/smilies/confused.gif)
do you haveany pics of the broken clips. AS for the c-clips, they are really stubborn, I could get my hand in far enough to touch them, so I bent a thin screwdriver on a 90 degree angle to pop the clips out(the good news is they just push back on) that is how i did mine.
Good luck with yours, it is alot of tedious work with alot of skinned knuckles.
No, I don't have any pics. The tool is just thin enough to get between the base of the handle and the fabric. When it "runs" over something, should I try to push it in further? That's why I think the angle in tool opening would spread the spring clip...but the tool bends.
I found on the Internet directions on how to use the handle remover. Just line it up with the long part of the handle and push. Worked the first time.
I also found out the hard way how the buttons work holding the upholstery in. The dang books don't cover the very basics.
yep, I found out the hard way too, personally I don't know who writes these books, but some chapters could have been written better by a 4 year old. I am glad you had some success removing the door panels. The internet is a wonderful thing for finding stuff like this.
Good luck with your car in the future.
Many of the little quirks a job may have could be explained by adding one sentence. Maybe the authors of these manuals have been doing the work so long it has become second nature and easily overlooked because of the idea, "everybody knows that."
Joshua Mollet
June 26th, 2015 09:16 AM
19magic73
January 13th, 2015 02:54 AM
19magic73
January 12th, 2015 07:41 PM
watkinsautobody98
March 8th, 2009 10:58 AM
