1970 Steering Wheel
Old August 21st, 2013, 02:36 PM
Elephant_Engine_Ernie's Avatar
1970 Steering Wheel
What would be the 'standard' wheel on a Cutlass S if the Sport Wheel wasn't ordered?
Elephant_Engine_Ernie is offline
Old August 21st, 2013, 02:39 PM
Frankenpez's Avatar
The top one is what my stock 1970 "S" came with. I can post a picture of it if that helps.
Frankenpez is offline
Old August 21st, 2013, 02:40 PM
Please do.
Old August 21st, 2013, 02:54 PM
stevengerard's Avatar
there was
Standard
Deluxe
Sport
the one pictured on top is a deluxe. the bottom one is "standard"
Someone else please confirm
stevengerard is offline
Old August 21st, 2013, 03:05 PM
Frankenpez's Avatar
This is a picture of when I found my Cutlass S in a shed. Bone stock from the original owner. Hope this helps.
Old August 21st, 2013, 03:21 PM
72 Olds CS
RetroRanger's Avatar
wow Ive never seen a standard wheel before !!! I wondered why the other one was called the deluxe now I know !!!
RetroRanger is offline
Old August 21st, 2013, 03:25 PM
brddg's Avatar
Option n30. I thought it was the janer wheel but the bbuild sheet says deluxe.
brddg is offline
Old August 21st, 2013, 04:11 PM
Never seen a standard wheel for sure but see the deluxe pop up every once in awhile.
Old August 22nd, 2013, 05:54 AM
Lansing built
1970cs's Avatar
Here is a 1970 dealer brochure for cutlass S.
Pat
1970cs is offline
Old August 26th, 2013, 01:12 PM
Lansing built
1970cs's Avatar
Here is another on a F-85 sedan 1972, also no vents on the dash? I understand the non/ac part with no lower ac outlets and the center upper should be a faux or blocked diffuser. But no side diffusers.
Pat
1970cs is offline
Old August 26th, 2013, 02:10 PM
oldspackrat's Avatar
The standard wheel is usually(only)? found on F85 cars? The no vent dash only came on post cars without AC I believe. Those cars had the kick panels with one pull **** & they had the wing(vent,fart) window in the door, that's why no side vents in dash.
oldspackrat is offline
Old August 26th, 2013, 02:28 PM
Lansing built
1970cs's Avatar
I found one per your specs. You are correct post cars with no AC.
http://columbus.craigslist.org/cto/4007782503.html
Pat
1970cs is offline
Old August 26th, 2013, 04:55 PM
BeenThere's Avatar
1970 steering wheel
The rim blow wheel was another steering wheel available for the 1970 Cutlass 442 cars. It was option N42, Deluxe steering wheel with instant-horn. Cost was $15.80. At first glance it looks like the Deluxe wheel.
BeenThere is offline
m455sx
February 12th, 2013 06:35 PM
1k442
February 8th, 2012 12:30 PM
1k442
February 2nd, 2012 10:54 AM
HOT-SHOT10
October 13th, 2011 12:22 PM
tomsw31
October 2nd, 2011 04:38 PM
Quick Reply: 1970 Steering Wheel
