1969 442 Sports Coupe Cowl Tag
I'd like to restore this car back to factory specs as closely as possible. My interior is all black but under the black on the head rest and dash I can see a gold color.
This is what I know so far:
1969 442 Sports Coupe (Built in Freemont)
Palomino Gold with Parchment Vinyl Top
Chrome Drip Rail Moldings and Chrome Moldings on the center post and around the side windows (Sports Coupe)
I don't believe it had factory ram air
Any help would be great.....
also B-80 is the drip rail moldings
B-90 is the side window frame moldings
Also E is Parchment vinyl top as you mentioned
344 olds/442
77 sports coupe
63 - Palomino Gold
and correct E is for Parchment vinyl top
good luck w car Dean
344 olds/442
77 sports coupe
63 - Palomino Gold
Thanks..I just got my new BLACK door panels in from OPG , Would they look right if I paint them or can I find gold interior parts somewhere? I'm guessing the dash pad can be painted...was the carpet gold like the buckets? The interior is in awesome shape. Gold headliner too?
At some point the engine was painted blue, am I right that everything but the brackets , accessories and intake were a bronze type color? Looks like I'll be taking the whole car apart... sweet. Hope I find that build sheet
I think they only made 25 442 sport coupes in 69...ac, power brakes,AUTOMATIC on the floor....does that sound right? I just bought the car a few days ago at an estate sale
you can paint them Parts Place sells 69 Mustard Gold return black panels (if you can) and buy gold ones from Legendary.
Yes dash pad can be painted same thing
yes gold carpet as well as gold headliner , package tray and wind lace.
If you already bought black panels and you like the black you could leave it but obviously up to you.
My 31 has gold interior if you want pics let me know
yes engine(intake ,oil fill tube, covers, water pump and balancer) should be bronze, brackets are black including alternator and a/c brackets.
There are plenty of pics here to reference or online.
if you find anything it will be under back seat, Freemont cars that I have parted out always found them there and quite detailed as well unlike Lansing
I can probably return them. I like the black but my intention is getting the most re sale. If it's as rare as I think I should probably try to stay factory I'm thinking....the black looks good. If I left it black I'd probably do the dash in palomino gold ....idk. I'll try to find legendary online...thanks again
Also the gauge on the far right where the clock would go is blank....is that normal? The Og owner just didn't opt for a clock and since it's auto there's no need for a tach?
Fremont cars are highly likely to have build sheet on top of gas tank, and not uncommon for there to be several others found in a Fremont car.
*In back seat springs, top or bottom
*under package tray
*in drivers seat back
*in door
*in "A" pillar
*in front fender
Steve
*under package tray
*in door
*in "A" pillar
*in front fender
Steve
my opine don't have two different interior colors it could turn off potential buyers
yes original buyer did not opt for clock in purchase so when that occurred you got a blank pod
Legendary makes the gold interior as mentioned, just to let you know try to buy from before holidays they will offer a sale then if you choose that route.
If you want to make the most back yes then I would go back to original on everything
Carsick - the Sports Coupe means it's got framing around all the door and rear quarter glass, unlike a hardtop coupe with has no framing there at all. Here's the difference between it and a HT (also referred to as Holiday coupe in a model 3687) The front clip, rear quarter panels, doors and most trim is interchangeable with 68/69 A body Cutlass/442 of similar style. 69 was the first year that Olds went from dash ignition to column lock too. BTW, the way your VIN is stamped is unique. I've only seen it spaced out like that in a handful of examples. It doesn't conform to the factory stamping guide in the Assembly Manual, but that means little. Your car was built close to the end of production in 69. IIRC Freemont shut down around the middle of July for retooling.
EDIT: ALL 69 -72 Post coupes and sedans have wing windows. Only the Hardtop coupes lost those starting in 69.
Sports Coupe
![](http://www.oldsmobilecentral.com/v5/uploads/2012-09-25-1969-442-3-640.jpg)
Holiday Coupe
![](http://www.remarkablecars.com/main/oldsmobile/oldsmobile-00015-2.jpg)
Last edited by Allan R; October 30th, 2014 at 11:14 AM. Reason: correction on model years
that is not true far as interchangeable the core supports are completely different from each year. The front fender bolt patterns are different from each year to accommodate each year's respective hood hinges. The rear quarters are different hence the different tail lights for each year. The only doors that will work would be from a 68 post not even 68 convertible doors would work.
68/69 interchangeability
Carsick there is very little from a 68 THAT INTERCHANGES w a 69 post car.
Hoods, trunks ,bumpers, signal and rear lights, hold moldings, trunk moldings, front fender moldings , dash (unless 68 a/c) kick panels, seats (unless optioned head rests), lower dash, rear marker lights and other misc are completely different.
The same front marker lights, manual antenna , glass, fenders can be used if you don't care about the bolt pattern and some items from engine compartment
Dean
Dean
Point taken. On quarters I should have specified 'skins' as I'm fully aware of the difference in tail light and bumpers. And yes, I know there's a different panel for verts and HTs. Forgot about the rad support, I should be more careful to specify fenders instead of clip as they mean completely different things.
The fenders are the same. The GM Parts manual says fenders for 68/69 (Group 8.130) shows (Part numbers 230796 RH and 230797 LH) for both years. Just the hinge is listed as different part number, as it likely has a different plate that bolts to the hood. Since the fenders are the same, it's very unlikely that there would be different mount locations for the bottom of the hood - just the top plate of the hinge where it attaches to the hood liner.
Why won't 68/69 post doors interchange? My interchange manual says they will. Same body style for both years. Similarly 70-72 Post coupe doors will interchange.
the different mount locations are on the inside of the fenders within the respective years w the obvious hood difference
the 68 doors via winged windows are different far as 68 convert and hardtop doors
the 68 hardtop door would def fit a 69 post just not the convert doors
so yes you are right re non convertible doors.
hope that helps
hope that helps
Nope, still somewhat confused by your comments
Then why would the parts manual have exactly the same fenders listed for both years? I don't buy that there are different mount locations on the fender. I do buy that the hinges have different upper plates for hood attachment though. Even the springs are listed as the same part from 68-72
That was never any part of my comment. Note I said
in my note to Carsick
huh? A 68 HT door will NOT fit a 69 Post. They're 2 different door styles and body styles. The post coupes have a B pillar whereas HT coupes doesn't, so trying to cross fit a HT door into a Post body would be a nightmare in labor to modify it. Methinks you're a bit mixed up on our discussion. POST doors will fit POST cars. HT doors will fit HT cars of similar body style. How did the verts climb into this conversation? Carsick doesn't have a vert and no vert I've ever seen has a post style door.
Is the issue of vent windows affecting the discussion of what will fit??
similar style
![](http://www.oldcarbrochures.org/var/resizes/NA/Oldsmobile/1968_Oldsmobile/1968_Oldsmobile_Prestige_Brochure/1968%20Oldsmobile%20Prestige-46-47.jpg?m=1371849555)
Nope, still somewhat confused by your comments Then why would the parts manual have exactly the same fenders listed for both years? I don't buy that there are different mount locations on the fender. I do buy that the hinges have different upper plates for hood attachment though. Even the springs are listed as the same part from 68-72
That was never any part of my comment. Note I said in my note to Carsick
[IMG]http://www.oldcarbrochures.org/var/resizes/NA/Oldsmobile/1968_Oldsmobile/1968_Oldsmobile_Prestige_Brochure/1968%20Oldsmobile%20Prestige-46-
47.jpg?m=1371849555[/IMG]
Yes 68 post doors (non convert doors) would work for his car
I think I said hard top which I wrote which is wrong
Yes he does not have a convert my point was the 68 convert doors are not the same as 68 hard top doors
So I did cause some confusion there apologies
first pic is a 68 fender
other pic is a 69
clearly different fenders
other pic is a 69
Allan,
I didn't read this all the way through but:
The 68 vent frame windows are different between hardtops and convertibles. The doors themselves interchange.
68 Post doors are probably the same as 69 but I don't know for sure. Dean can probably tell you.
I don't know why the interchange book would show 68-69 fenders as the same. 68 fenders had a two hole pattern. Early 69 fenders had a three hole pattern. At some point in 69 I think they went to the dual pattern fenders (five holes) with only backer nuts in the 69 location. Then replacement fenders had the five hole pattern with backer nuts in all five places.
The hood bolt holes on the upper hinge are not the same from 68-69. 68 used three bolts and 69 two. No two of the holes line up between the two years. You can bolt a 69 hinge to a 69 fender but then a 68 hood will not bolt to the 69 hinge without reaming/elongating/moving holes
You'd have to be a moron to bolt a 69 hood to a 68 hinge so I won't even go there
![Big Grin](https://classicoldsmobile.com/forums/images/smilies/biggrin.gif)
Allan,
The hood bolt holes on the upper hinge are not the same from 68-69. 68 used three bolts and 69 two. No two of the holes line up between the two years. You cannot bolt a 69 hinge to a 69 fender and bolt a 68 hood to it without reaming/elongating holes
Mike look at pic far as 69 fender
oh couldn't find your thread far as what you just explained
This is the difference in the vent windows. Convertible vent frame is on the right
Not sure what you mean about looking at the pic of the 69 fender
![](http://imageshack.us/a/img577/9379/sblg.jpg)
I will post 68 and 69 hinges tom as well as side by side pics of a 68 and 69 fender
granted my pics are not side by side w both fenders included but the first pic clearly only shows two holes thus 68. The pic next to it shows 5 holes - 69.
The 68 hinge is longer in width where it bolts to fender when they changed it in 69 they went w a smaller base in terms of width
#33
#34
Thanks to everyone for all the very valuable information. My car unfortuatly is not a w32 ( no ram air and I don't think any w32's had a/c). I ordered my new white vinyl top (Im hoping it will look close to the original parchment) Seeing as this car is one of 2,475 422 Sport Coupes made in 69 and not a w32 i dont think im gonna go back to the gold interior. im thinking im going to go with polomino gold (exterior color) on the dash and leave the rest black. It has black stripes on the hood which im not sure if were factory but im thinking of going with white stripes to match the top. I also ordered a new drivers side fender to save me the headache and time of getting it straight. Is it hard to mark out and drill the holes for my peak molding ? Im pretty sure the new fender doen't have the holes pre stamped.
Im also going to be pulling the motor out soon to repaint it and the engine bay. Ive read that Bronze was the color of all the 442 engines (except the 455). Should my intake be bronze as well? what color should my accessory brackets be? I picked up some Grey manifold paint for the exaust manifolds. Im assuming the pulleys are black.
U guys are awsome Thanks
#35
does your hood have pin stripes and the panels painted black or just the pin stripes outlining the raised panels? The pin stripes were part of the 442 packaging as well as a stripe around the trunk.
yes on the bronze and yes intake gets painted. Brackets and pulleys black
#38
