1953 Olds interior door release lever removal
Old Feb 4, 2012 | 12:44 PM
lmarquette's Avatar
Hi. Hopefully someone can help me figure this out. How does one remove the interior door release lever? A previous owner has removed them at some point and reatached with the lever pointing toward the small vent window crank. Now they hit when you try to open the small vent. I'd like to remove the door lever and put back to the original angle but dont see a locking nut as a way to remove. Any help would be greatly appreciated.
Thank you,
Lee
Old Feb 4, 2012 | 08:26 PM
Nailhead 88's Avatar
Junior Member
tool to remove the handle
you need this tool > http://www.tooltopia.com/_img/KDT/KDT431.jpg
to remove the horseshoe clip slide the tool next to the handle and push it off
then reposition the handle
if the clips on the wrong way go at it from the other direction
Old Feb 4, 2012 | 08:35 PM
Junior Member
removal
click on the link http://www.classychevusa.com/index.c...707/prd707.htm
this is what your dealing with
there also a spring pressing on the round nylon/plastic
piece
put the tool between the round piece and handle shaft and push the clip off
Old Feb 5, 2012 | 06:45 AM
lmarquette's Avatar
Wow! Thanks for the help and great photos.
Old Feb 5, 2012 | 10:27 AM
Junior Member
Sure thing, that's what the forum is for to help one another
Good Luck with the 53 Olds
Nop
Nov 13, 2013 11:46 AM
TommyT
Oct 19, 2012 01:52 PM
ctrain22
Jun 14, 2009 06:09 PM
oldroyale
Jun 6, 2009 03:18 AM
Alocatelli
Jul 24, 2007 09:17 PM
