A/C Under Dash Venting
Old Jul 16, 2010 | 06:13 AM
Dool Cat's Avatar
I have a 72 Cutlass S which came factory with A/C, however the previous owner removed the unit and blanked off the opening. I have recently purchased a unit from a 71 Cutlass and in the process of installing in the near future. I did some investigating under my dash and as seen on the photos I have duct/vents to driver and passenger grilles but not to center console. When I run my heater the air only comes out of the box on the floor and not my vents, is this the way it is designed. The opening the heat comes out at the floor appears to have been cut out or is this factory. Do I have a faulty A/C controls or does the opening on the bottom need to be covered to redistribute the air?
After further investigation I believe this is the heater box, not 100%
Old Jul 16, 2010 | 07:03 AM
You appear to still be missing some duct parts. There is no duct to the console, but there is a diffuser that bolts to the bottom of the HVAC box to distribute the floor air. Console cars got a different diffuser than bench seat cars. The console diffuser directed air at the two footwells, whereas the bench seat diffuser let the air flow straight back.
In heat mode air is only supposed to come out the floor outlet. If you use the vent mode and set temp to hot, you'll get heat out the dash vents.
You appear to be missing the curved duct that connects the center vent (under the speaker) to the top of the HVAC box.
Old Jul 16, 2010 | 07:32 AM
Bluevista's Avatar
Registered
Had these from the last AC duct problem, may help some.
Old Jul 16, 2010 | 08:11 AM
Dool Cat's Avatar
Looks like what I am refrencing is a heater box, not 100%?
ah64pilot
Apr 9, 2012 02:55 PM
67Olds442X2
May 22, 2011 05:28 PM
philnjean
Oct 13, 2010 12:57 PM
one4theroad
Oct 10, 2009 01:54 PM
glord
Jul 21, 2009 11:23 PM
