What is this sensor?
Old May 18, 2025 | 05:58 PM
deaddds's Avatar
It’s right next to the coolant sensor but I’m not sure what this is.
Old May 18, 2025 | 07:04 PM
Any idea of the Year of the vehicle?
Old May 18, 2025 | 07:59 PM
Sugar Bear's Avatar
Hard to tell for certain from the picture but it looks like the coolant temperature sensor for the Computer Command Control system, not the sensor for the temp light or gauge... brought to you by one of JoeP's old posts...
Old May 19, 2025 | 05:47 AM
69HO43's Avatar
That is an ORIGINAL coolant temp sensor for the CCC system. It's a major player in putting your engine into closed loop or not. Yours has suffered a fate many has seen over the years.
AC Delco/GM p/n 25036092, and is available some places as Standard Motor Products TX1. But the connector and sensor types must match.
sensor-temperatura-refrigerante-century-regal-25036092-1984-D_NQ_NP_879919-MLV28340803863_102018-O.jpg
The connector is ACDelco/GM p/n 12014843. Which is what you have, but in a couple of pieces.
In the mid-80s, they resolved issues with the pigtail coming loose/breaking (like yours), and corrosion, etc., causing the computer to stay in open loop. Not good. So they came out with an updated sensor/pigtail package to replace any warranty or failed parts that got replaced. Soon after, they started selling the new sensor and pigtail separate.
If you want the updated ECM sensor and connector, you will need AC Delco PT169, GM# 12101899 superseded to 88987993 for the sensor connector. The sensor itself is GM# 12146312 superseded to 15326386.
Old May 19, 2025 | 06:11 AM
Year? Model? Engine?
Old May 19, 2025 | 06:53 AM
deaddds's Avatar
1983 ho 307
Old May 19, 2025 | 06:55 AM
The outboard sensor is the coolant temp sensor for the CCC system. The one closer to the t-stat housing is the sender for the gauge or idiot light.
Old May 19, 2025 | 06:56 AM
deaddds's Avatar
So there are two coolant sensors? There is a single wire sensor right next to it.
Old May 19, 2025 | 07:52 AM
Pretty sure I just said that.
Old May 19, 2025 | 08:01 AM
deaddds's Avatar
Thanks for all the info. Going with the updated connector.
Old May 19, 2025 | 09:59 AM
deaddds's Avatar
Yeah, it posted before I got the latest
Old Aug 10, 2025 | 07:37 PM
Olds Dad's Avatar
Collector of Stray 55's
I have an 84 Toronado Caliente and the CTS and temp sender look
exactly the same (right down to the broken connector).
I see the information regarding the updated CTS / pigtail combination. For the Caliente with digital dash gauge would you know is this same part would work (or which one would)?
Old Aug 11, 2025 | 05:12 AM
CutlassMarc's Avatar
Are these just for olds with the CCC or a all gm ccc v8's cars?
Mine is a M/C SS 86 and most likely fine. but if the same, I'll print this and add it to the dealership service manual just in case I ever need this.
Kellyann3570
Jun 14, 2023 12:29 PM
Andrew Brennan
Sep 7, 2021 03:44 PM
ChibiDuo
Sep 28, 2020 06:05 PM
Boilerz25
May 10, 2020 06:07 PM
