Hurst air breather
Old Feb 18, 2012 | 11:49 AM
69OLDSCUTCONV's Avatar
Hurst air breather
Looking at hurst air breather bottom does anyone have the measurements were the drivers side air breather tube is in relation to the passenger side hole.
Old Feb 18, 2012 | 12:49 PM
I'm sorry, I'm not sure what you're asking? Is the for a 69 H/O?
Old Feb 18, 2012 | 04:34 PM
I bought a top hat from tony. It only has one hole for a grommet on the passenger side I need some measuremnts to locate where the one the drivers side should be
Old Feb 18, 2012 | 04:50 PM
Sorry, I'm still not following you. Is there anything in these pics that is helpful?
Old Feb 18, 2012 | 05:10 PM
on the bottom half of the air breather there two holes for grommets one close to the snorkel I have that one need location of the other one that the. Driver side valve cover vent goes into
Old Feb 18, 2012 | 07:20 PM
thansk
in your last picture you sent you can see the driver side valve cover vent tube pairly peaking around the corner of the breather housing. my question is the location of the hole in the bottom breather pan that the driver side valve cover vent tube. I can tell approx where it is by lookinmg at the actuall top hat because it is nothced to go aorund the two breathers and the snorkle but was wanting a measurement.
Old Feb 19, 2012 | 05:54 AM
HairyHurst's Avatar
69, I got a air cleaner assembly from tony to, same deal no vent set up on left hand side of air cleaner base. I had all the parts, vent filter, rubber connections and a pipe to match the right hand side. I put the air cleaner base on the engine along with the vent, rubber connections and pipe as so that I could mock up where to drill a hole to fit the rubber pipe connection, worked fine for me. I have not figured how to send pic's or I would have sent you a couple.
Old Feb 19, 2012 | 12:54 PM
Randy Neill's Avatar
hurst olds air cleaner
Who is this tony you speak of. I have a 69 H/O the only thing missing was the top part of air cleaner. Would like to find one. Any help would be appreciated.
Old Feb 20, 2012 | 02:36 PM
Tony Bonnafide (spellin) he is in New Jersey. WHen I bought mine he only had one left. they are repro but he does a nice job with them. he was advertising on ebay back then, maybe 6 months ago
Old Feb 22, 2012 | 06:21 PM
firefrost gold's Avatar
I will get mine and take some shots of it and get the wife to post them. If looking at the air cleaner base with the large air horn to your left go from the large opening edge to the first small hole is 3.5 inches to center and then 20.75 to the second hole
Old Feb 23, 2012 | 02:07 PM
https://classicoldsmobile.com/forums...1&d=1330034843
Old Feb 27, 2012 | 03:25 PM
Thank you so much, I wanted to have a reference before making the second hole.
Old Feb 27, 2012 | 06:33 PM
the second hole is reenforced with the rolled edge just like the first hole that will be hard to might be able to weld a washer on not sure if it needed .
jensenracing77
Mar 23, 2010 09:19 AM
k9ulan
Aug 21, 2009 12:55 PM
jensenracing77
Feb 22, 2009 07:02 PM
bjtstarfire
Jan 19, 2008 03:55 AM
