Build Sheet???
Build Sheet???
Do any of you H/O guys know if Oldsmobile (or Hurst) relocated the the build sheets after the Hurst mods were completed? I'm familier with the usual locations for the other "regular" cars from the Lancing factory (under drivers seat, under back seats, etc...), but was wondering if the H/O's were unique?
or THIS?
I think we're both thinking the same thing. But on the other hand if he's actually got a true M build sheet, I also wanna see it!
Certainly true for 68-69 cars but 70-72 build sheets seem to be found with more regularity
Actually, I did know the difference but wasn't careful enough in my nomenclature. You are correct, what i found is the broadcast card. The car is in storage and I will not be around it for another couple of weeks. I will post pics as soon as I can.
Randy
Randy
I guess the word sheet is the hangup, because many people confuse build sheet with broadcast card.
I'll believe it when I see it.
You can email me at Kurt.Shubert@wildaboutcars.com
Please show me a 1970 Lansing Build Sheet. Not a Broadcast Card, but a Build Sheet. Or a '71 or '72 for that matter.
The rumor or tales of found Lansing build sheets is getting close to the SMW 403 myth. Fact is they did exist, but were disposed of before the cars left the assembly plant. They were not needed anymore, only used to build the car. Not for future restorers to discuss and use to make their cars worth more.
Good info, guys. I've had my '72 Hurst for 30 years so my knowledge is limited to the '72 H/O's, which were plucked from the Cutlass Supreme line in Lansing and trucked to Hurst for the final assembly. I'm wondering if the build sheets could of stayed with those perticular cars. From what I read here, probably not. Regardless, I'm going to replace the carpet and seat covers in my car soon, and will post pics of the broadcast and/or build sheets if I get lucky. The only sheets I'll probably find in my car will be rolling papers! Thanks for the replies guys.
Best of luck with your project. Fill us in with details and pics as you go.
Allan, you got Randy and I mixed up. I have not found a broadcast card in my Hurst (yet). No biggie (hum, on the other hand, I wouldn't mind if the community thinks I own a '70 W/30 like Randy's). I'll be digging into my interior in a few weeks. Again, good info by all.
Thanks for the numbers info. Iv'e never seen that pdf before...very cool. While my car is not a W/30, it has the W45 stamped on the cowl tag. I believe you are correct about the cars being built in April (mine is O4D). Olds and Hurst had an aggressive advertising blitz leading up to the Indy 500.
Dan, that is the first semblance of a Lansing Build Sheet that I have ever seen. It is not the "regular" format Build Sheet as existed in '69, nor is it the Fisher Body Broadcast Card though the form is similarly structured. Do you know where it came from? A H/O, I know, but was is originally found in the car?
Randy, no offence intended, but do you know the difference between a build sheet and a broadcast card? I think you've most likely found a broadcast card. Does it look like this?
or THIS?
or THIS?
#31
So, these larger sheets, Gator has one for his '69, what would they be called? Per the 3 below, the 1st one was posted earlier I have, was from a 1969 H/O owned by Ed Nunez in Cali I believe, not sure where it was found.
The second one below, is from a buddy of mine Chuck with a 1969 H/O and it was found under the front seat carpeting.
The last one is from my 1967 Toronado, I found folded in my glovebox with the protecto place. Person I bought the car from said and it was saved by the original owner who was an Olds salesman so possibly he came about it in good shape, I have no idea if that is true.
They all have 'Oldsmobile Production Code' at the top on them, they are bigger than the broadcast card but not the typical build sheet.
#32
Body broadcast sheets?? Ive seen these before,
Chevelle sheets that looks like the Lansing sheets
http://www.chevellestuff.net/1964/bs.htm
#33
#35
Hope you don't mind, I copied those documents into an efile for future references. Thanks so much for sharing them.
I notice a similarity on both the 1969 and 1969 Production Code sheets. They are both labelled "B" codes. What significance is that?
#39
