:) is all i am going to say... THEN :(
Old Jan 6, 2011 | 05:32 PM
sicky olds's Avatar
NôôB
So i decided after driving the hurst today to do a donut in the cul de sac (Thanks Jamesbo) and obviously i took a video of it. So thats the . Now for the she wont start idk if i jostled something loose (didnt seem like it) or what. letting her cooldown in the garage (which i had to push up with my caprice, thank god for the push bars lol). Well anyways ENJOY and i hope you like lol
http://www.youtube.com/watch?v=IoBr0j5UNT4
Last edited by sicky olds; Jan 7, 2011 at 06:47 AM. Reason: found out how to spell Cul De Sac lol
Old Jan 6, 2011 | 05:51 PM
Toms 69-76 Custom Vista's Avatar
I like the video Nice POWER Does it just crank or when you turn the key with no sign of life? Tom
Old Jan 6, 2011 | 05:55 PM
gearheads78's Avatar
car guy
Where's the guy shaking his head back and forth smiley when you need it?
sicky olds's Avatar
NôôB
it clunks lol. and it was awesome too the cloud stayed in the air for about an hour or 2 and it smelled like a drag strip lol IT WAS AMAZING
BIGJERR's Avatar
I bleed Oldsmobile
A Hurst with no posi?
Old Jan 6, 2011 | 05:56 PM
sicky olds's Avatar
NôôB
thanks gear i actually laughed on that one, i couldnt resist it and there may or may not have been a girl i was trying to impress (seems the bottom of all problems)
Old Jan 6, 2011 | 05:58 PM
sicky olds's Avatar
NôôB
i am pretty sure it does (has the original rear end as far as i know and when the rear is up and you spin the one tire the other one catches like it should)
CORRECTION: I should assume it does lol, finding out a lot of things on this car arent original!!! but still loving it none the less
Old Jan 6, 2011 | 06:19 PM
Rickman48's Avatar
As my Dad woud say;
You bought it,
you broke it,
YOU FIX IT!!!
Old Jan 6, 2011 | 06:21 PM
sicky olds's Avatar
NôôB
hey i have no problem with fixing it lol. ask anyone who has seen my other forum threads thats all i do on this lol. just trying to figure out whats wrong with this one. will try to get a vid posted of the noise in a few to get an idea from you guys
Old Jan 6, 2011 | 06:24 PM
OLD SKL 69's Avatar
GM Enthusiast
Well, they were designed to have fun with. Hopefully whatever is wrong is no big deal.
Old Jan 6, 2011 | 06:52 PM
citcapp's Avatar
Picture says it all
Old Jan 6, 2011 | 06:57 PM
sicky olds's Avatar
NôôB
uploading video on youtube since site doesnt like em lol
Old Jan 6, 2011 | 07:04 PM
sicky olds's Avatar
NôôB
http://www.youtube.com/watch?v=Tvq0cd_AQxg
sound of the clukning
Old Jan 6, 2011 | 07:20 PM
firefrost gold's Avatar
put a wrench on the front crank bolt or A big socket see if you can turn it over by hand I once sheered all the bolts off a fly wheel when doing the same thing
with a 4 speed had it all wound up power shifted to second and clangity clang clang Very easy to over rev doing silly thing while showing off for split tail.
Old Jan 6, 2011 | 07:23 PM
sicky olds's Avatar
NôôB
grrrr that doesnt sound like fun... it was funny cause it ran fine when i let it sit then i turned it off and then went to start it up again and nothing
Old Jan 6, 2011 | 07:26 PM
sicky olds's Avatar
NôôB
so if i can turn it is that good or bad? just geting info b4hand lol
Old Jan 6, 2011 | 07:28 PM
car guy
Sounds like you blew it up and its locked up to me. Can you turn it over by hand with a wrench? Donuts = oil slung up away from the pickup = locked up motors with ugly pictures of the insides posted at a later date. I hope I am wrong but it does not sound good.
Old Jan 6, 2011 | 07:29 PM
sicky olds's Avatar
NôôB
lol well i was talking about rebuilding it so.....
YAY ME!!!!!
Old Jan 6, 2011 | 07:36 PM
sicky olds's Avatar
NôôB
just so i dont mess this up anymore how do i hand crank it, tried to look it up but no bueno
Old Jan 6, 2011 | 07:48 PM
car guy
A long braker bar on the crank bolt. If you pull the plugs it will make it easier. Also look at each plug for any mechanical damage and make sure you don't see any coolant come out any plug holes.
Old Jan 6, 2011 | 07:51 PM
sicky olds's Avatar
NôôB
what size socket do i use? or will the breaker bar fit right in the hole? in case you havent noticed novice on this stuff lol
Old Jan 6, 2011 | 07:52 PM
what does the oil look like ? Will need a socket and its on the balancer. will have to go thru pullys so will need a deep or extension too.
Old Jan 6, 2011 | 07:54 PM
sicky olds's Avatar
NôôB
ok so it sounds like i need a checklist here to check out, so far its;
Spark plugs
Oil
Hand crank to see if it turns easy
Anything else i am missing? will post pics of all this stuff tomorrow. too dark outside right now and kinda tired of messing with her tonight lol
Old Jan 7, 2011 | 02:22 AM
Bluevista's Avatar
Registered
It sounds like starter heat soak or a bad or low battery or loose wiring connection?
If it's heat soak the car should start a few hours later or in the morning after it cools down.
Check the battery charge and electrical connections and ground straps if that doesn't work. See if the starter came loose and isn't engaging the flywheel correctly.
If it isn't that the advice to check to see if the engine turns is good, then go from there if it moves. I can grab the belts and move mine, a socket on the balancer bolt works a lot better. I hate to say this but If you spun a bearing or did some other internal damage it could of seized up the engine after you shut it off. It did have oil presure and it was up to level I take it? That spinning around could of forced the oil away from the pump pick up and...lets just hope the engine turns over and it's the battery or something with the starter.
Old Jan 7, 2011 | 05:13 AM
Nilsson's Avatar
It is most likely the starter. Remove starter and secure it then jump it with cables from a know good battery.
Old Jan 7, 2011 | 05:22 AM
Lady72nRob71's Avatar
Big honkin' socket (about 1" or bigger) on a 1/2" ratchet or breaker bar.
Put that on the bolt that holds the crank pulley. Now pretend you are tightening the bolt and turn the thing clockwise. It should turn with some effort. More effort if the plugs stay in. If standing on it will not turn it, then it is possibly locked.
Old Jan 7, 2011 | 05:24 AM
Sicky,
I hope it's the starter too.
X 2 on all the above. You might also try.
Get a tire iron and a buddy.Get your buddy to try to start it while you're under it banging the tire iron on the starter.
BE SURE IT'S IN PARK
Bye the bye It's "Cul de sac" and there are 43,560 square feet in an acre. [Real-estate jargon]
Old Jan 7, 2011 | 05:34 AM
car guy
You can see the motor try to turn. Thats why I don't think its the starter but like I said I hope I am wrong. "
Old Jan 7, 2011 | 05:39 AM
sicky olds's Avatar
NôôB
yeah i think it might be the motor as well... you can see in the video that the alternator turns slightly but only slightly. but i am def starting with the cheapest problem first. Guess this is one of those lessons learned most def, and glad i got video lol
Old Jan 7, 2011 | 05:48 AM
71supreme's Avatar
Great vid
I agree, check your battery, cables & starter 1st, lots of things can get jostled when going fast in a circle. It happens in my mind all the time, but in that case, I just sit down, close my eyes, take a couple deep breaths, and slowly stand up again.
I once took a long trip in my Olds, and when I came back, and jumped in to go to work the next morning, it made the same noises yours did (or lack of noises) It wound up being a cut cable from somewhere along the road home. Here's hoping that's it. Good luck!
Old Jan 7, 2011 | 09:21 AM
  #31
alek72us's Avatar
Olds Dreamer
The socket to turn the crank of my 455 is 1.1/8 its a big socket i dont know what olds 350s take. but chevy small blocks take a 5/8 socket. and it shouldnt turn really easy. but it shouldnt take all ur muscle to turn it.
Old Jan 7, 2011 | 09:24 AM
  #32
sicky olds's Avatar
NôôB
so i need to pick up one of those sizes then. cause when i vaguely attempted the biggest socket i had wouldnt fit. Thanks for the info
Old Jan 7, 2011 | 09:38 AM
  #33
alek72us's Avatar
Olds Dreamer
i just hope u didnt drop a valve and its laying on top of the piston. its looks to me like it wanst to move but something is stoping it.
have u tried to jump it and give the battery more power? incase it is ur starter.
also when u do turn ur crank over by hand. if it does turn over turn it 180 degrees one way then 180 the other.
Old Jan 8, 2011 | 06:34 PM
  #34
sicky olds's Avatar
NôôB
tried to hand crank the engine and NO BUENO on that one... ordering an engine mount hopefully this weekend and finding out whats wrong and doing to rebuild i was going to wait on lol
Old Jan 8, 2011 | 07:19 PM
  #35
Cameo White's Avatar
Smile
Hey Sicky,
I hope your engine is OK. You going to pull the whole thing?
Old Jan 9, 2011 | 01:48 AM
  #36
Mind if I ask WHY?
Old Jan 9, 2011 | 03:35 AM
  #37
jensenracing77's Avatar
Originally Posted by Jamesbo
Mind if I ask WHY?
i think he is talking about an engine stand.
Old Jan 9, 2011 | 04:36 AM
  #38
oldzy's Avatar
Old Jan 9, 2011 | 05:12 AM
  #39
sicky olds's Avatar
NôôB
Yeah I meant engine stand lol.
Old Jan 9, 2011 | 06:17 AM
  #40
Dang - sorry to hear about the bad news.
Guess I will refrain from doing donuts in my cars...
Let us know what you find out once it is apart.
Best of luck!
