79 h/o
Old May 19, 2016 | 10:19 AM
pav8427's Avatar
79 h/o
My H/O seems to be missing the H/O emblems that belong on the b(?) pillar between 1/4 windows and rear window.
Can anyone out there with one tell me if they are the same as the one on the trunk lid?
My thoughts are that if I cant find a set that I should be able to scan and 3D print a set.
Thanks , Doug
Old May 19, 2016 | 12:24 PM
Yes, they are the same. Part number SE79LHO from Fusick.
Old May 19, 2016 | 12:37 PM
pav8427's Avatar
I did run across them. Thanks.
Another quiz. Anyone happen to have the layout as to where they are positioned on the car?
Old Sep 25, 2016 | 06:37 PM
ChadF's Avatar
In case you still need the positions, they are 80mm from the crease line behind the rear window to the front edge of the emblem and 95mm from quarter panel crease line to the bottom of the H on the emblem.
