1969 Hurst/Olds vacuum line routing
Old Oct 5, 2022 | 12:50 PM
alsmith787's Avatar
I've looked at my Assembly Manual & Maintenance Manual it's really vague does anyone have a more user friendly schematic that makes sense? also the "T" inline mine is in the front I've seen that "T" in the rear of the engine. All I'm looking for Guys is something that makes sense so I can duplicate it as it was coming off the factory floorThanks for the helpAlsmith787
Old Oct 5, 2022 | 02:58 PM
69 Hurst's Avatar
Olds Fanatic
Maybe this will help. The line from manifold vacuum gets the "T" and splits off to the transmission modulator.
Old Oct 5, 2022 | 05:34 PM
1969Hurst's Avatar
Tossed this together some years back....
Old Oct 5, 2022 | 08:36 PM
alsmith787's Avatar
Thanks it does help greatly two questions - so there are 2 "T's" one in the front of engine one at the back of the engine firewall end --------- last then on the air cleaner the valve at the end of the snorkel valve that hose goes from there to one of the thermal valve on the bottom of the air clean the 2nd barb of the thermal valve goes from there to what????
thanksAlsmith787
Old Oct 6, 2022 | 06:33 AM
1969Hurst's Avatar
Damn... my diagram was messed up in that area, just revised it, thanks for the questioning!
Old Oct 6, 2022 | 09:36 AM
briane's Avatar
The Vacuum Bulb in your diagram, is that with A/C?
Old Oct 7, 2022 | 05:39 AM
alsmith787's Avatar
Ok H/O experts vacuum lines
Finishing up my 1969 H/O engine vacuum line routing (And You Guys have been AMAZING with factual information)
SO everyone I know the assembly & Maintenance Manual call out a COLOR CODE on the vacuum lines
Air Cleaner --- black/white tracerAlso trans module black/blue tracer - well also black/yellow tracer black/red tracerIs that correct? Did Oldsmobile really do that to the 442 before it shipped to Demmer? I know the flapper valve had a solid black hose that they cut a existing hose put a T in it going to the flapperCan some explain all of this to me - the color thing on the vacuum hose seems like the factory wouldn't do that - Am I wrong? Or is that correct?
Old Oct 7, 2022 | 06:07 AM
Yes, that's your climate control vacuum can. No AC, no can, I think.
Old Oct 7, 2022 | 07:03 AM
69 Hurst's Avatar
Olds Fanatic
Here is how I have mine...
alsmith787's Avatar
69hurst pdf file
Could you send that PDF in a different format it can't be opened I'm interested in this OEM Color Coded vacuum hose seems odd the factory would do that given that every penny is equated into price just trying to get to the truthPlease let us see your vacuum hose layout very interested
THanksAlsmith787
Old Oct 7, 2022 | 07:08 AM
69 Hurst's Avatar
Olds Fanatic
pdf's are a pain...
Old Oct 7, 2022 | 07:17 AM
69 Hurst's Avatar
Olds Fanatic
Yup!
Old Oct 7, 2022 | 08:03 AM
I merged your 2 threads, there is no need to start multiple threads for the same thing.
Old Oct 7, 2022 | 10:49 AM
alsmith787's Avatar
69 H/I heater valve for A/C car
Quick question -- I have the valve think you guys called it a bubble valve? This is the vacuum operated heater valve on the rear of the engine by the firewall I have a plug/hose nipple with heater hose clamped I need to replace with valve
Any suggestions of how to remove really can't swing a pipe wrench in there I'm kinda baffled also worried about breaking now the base is either a 1" or 1 1/16" pentagon/5 sided? Anybody done this before? Or Any Ideas?
Old Oct 9, 2022 | 04:16 PM
1969Hurst's Avatar
On mine I am able to get a 7/8 wrench on the base and have room to loosen / tighten if needed.
WTony
Jan 15, 2020 06:51 AM
ericjimmysfla
May 22, 2015 07:50 AM
Funkwagon455
Aug 28, 2014 09:22 PM
pacekar
Hurst/Olds
Sep 16, 2013 01:46 PM
69OLDSCUTCONV
Hurst/Olds
Jun 14, 2012 08:37 PM
