What Brand of Water Pump?
Old Oct 3, 2015 | 04:57 PM
RandyS's Avatar
The water pump on this motor (pic below) is starting to weep. I've replaced the lower hose so I am pretty sure it is the pump. What brand of pump do you all recommend? I see Cardone and Airtex available from Rock Auto, plus some others I am not familiar with. Which one moves the most fluid?
Old Oct 3, 2015 | 08:39 PM
That's a good question. The factory pumps had a cast impeller with an integral disc while most reman pumps have a stamped impeller that is open (no disc). Also, the 70 and older pumps had a larger diameter hose fitting than the 71- up, so would the early move more coolant?
So I have no idea if there would be a difference in flow between different brand reman pumps.
Old Oct 4, 2015 | 11:20 AM
76olds's Avatar
Hookers under Hood
I put a Milodon high volume aluminium pump on my 76 350 MIL-16285 with a robertshaw high flow tstat.
When looking down in the rad while purging the air locks, I didn't notice coolant flowing through the tubes any quicker than with my stock iron pump. I have since installed a 2 row 1" tube, Be Cool rad it may flow different than the OEM 3 row rad, but I don't know.
Good question indeed.
Eric
Old Oct 5, 2015 | 09:45 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Or you could have this (possible OEM Delco) pump rebuilt. Nothing like OEM.
Old Oct 5, 2015 | 11:08 AM
RandyS's Avatar
Still looking for info on what is considered the 'Best' replacement pump.......
Old Oct 5, 2015 | 11:26 AM
DJS70cutlass's Avatar
Go with a Flowkooler you wont be disappointed Just installed one on my 350 and it's a night and day difference!
http://www.flowkoolerwaterpumps.com/...174884e018d048
Old Oct 5, 2015 | 11:42 AM
RandyS's Avatar
Thank you, but I guess I should have worded my last post more carefully. (cheapskate here)
Old Oct 5, 2015 | 12:36 PM
Majic Jack's Avatar
A-1 Cordone is an excellent remanufactuer, good quality control, never had an issue with any of their units.
Old Oct 6, 2015 | 06:48 AM
Randy do you have a good higher end parts vendor in your area? NAPA, Federated, United etc...? Check them out they usually have the better non chinese junk parts. Keep the bad pump in a box vs turning it over for the core charge if its original or if that even matters to you.
Old Oct 6, 2015 | 06:50 AM
RandyS's Avatar
Yes, we have all the major players here. I will check with NAPA. Thanks!
Old Oct 6, 2015 | 08:00 AM
If you don't have any cooling issues, get one spec'd for your accessory equipped model. Just double check your impeller nose length before painting. A1Cardone has been good for me also. As always, I suggest if you have not replaced your timing set, now would be a good time to do it as your just a few bolts away.
Old Oct 6, 2015 | 12:17 PM
RandyS's Avatar
Brand new motor, less than 100 miles on it..... did not replace the WP.....
Old Oct 6, 2015 | 12:31 PM
RetroRanger's Avatar
72 Olds CS
i just ordered the airtex for my 455, the cardone one did not state the WP snout length and i couldnt find it on their page ...the airtex stated 5.5" so they won the coin toss. they were about the same price.
my past experiences w cardone have been positive.
Old Oct 6, 2015 | 01:46 PM
Hairy Olds's Avatar
Shoveling Snow
Have the pump rebuilt!
Old Oct 6, 2015 | 01:50 PM
[QUOTE=RandyS;863659]
If you don't have any cooling issues, get one spec'd for your accessory equipped model. Just double check your impeller nose length before painting. A1Cardone has been good for me also. As always, I suggest if you have not replaced your timing set, now would be a good time to do it as your just a few bolts away.[/QUOTE
Not saying a word, I did the same thing a few years back.
Nor Cal Andy
Mar 29, 2012 07:27 PM
72Ctlss
Jun 23, 2009 03:12 PM
greener_dude
Feb 18, 2007 08:14 PM
SMOKEYMTNKUSTOMS
Jun 21, 2006 04:42 AM
SMOKEYMTNKUSTOMS
Feb 21, 2006 11:16 AM
