Doing it the right way
Old May 2, 2014 | 06:01 PM
cutlassefi's Avatar
Just thought I'd post this for those who haven't seen what it looks like to do it the right way.
http://speedtalk.com/forum/viewtopic...a4bde6e73f7e5d
Old May 2, 2014 | 06:50 PM
TripDeuces's Avatar
It's amazing you can see the pull right where the bolts go. Good stuff. So glad I used a honing plate
Old May 3, 2014 | 07:14 AM
drjr56's Avatar
How to know it wasn't done right after someone else does a rebuild.What would be a way to tell.This is good to know before getting a engine rebuilt,so ya can make sure to have it done right.Or at least ask if it's gone to be done.If not fine a builder that will do it right!
Old May 3, 2014 | 08:41 AM
Octania's Avatar
" It does make a difference studs VS bolts."
Shouldn't the hone plate be made of material that behaves identical to the cast iron or AL head to be used [AL is 1/3 as rigid as steel, not sure where unsolid cast iron falls in there] ?
Also, if studs vs bolts matters, the same type hardware should be use for honing with the proper type plate. No, let's go further- THE EXACT SAME FASTENERS should be used, torqued by the same technician, using the same tool, in the same sequence.
To be as nearly perfect as possible.
I am not being facetious at this time.
dschallock
Suspension & Handling
30
Sep 15, 2016 04:42 PM
ATrain1
Non-Olds Engines
Jun 29, 2012 12:58 PM
Oldsguy
Nov 28, 2010 12:31 PM
344870M
Aug 21, 2009 08:04 AM
derek nesdoly
Care and Appearance
May 29, 2009 04:23 AM
