Motor mount header clearance
Old Mar 30, 2014 | 08:35 PM
Napoleon1991's Avatar
I just installed hooker headers on my 69 cutlass and i am worried about the motor mount clearance on the drivers side. One of the header tubes is about 3/16 to 1/4 inch from touching the motor mount and i was wondering if that will be to much heat for the mounts or if its ok.
Old Mar 31, 2014 | 06:46 AM
I suspect you will be fine, but if you are losing sleep over it, consider fabbing a sheet metal heat shield.
NMcCarthy
Nov 16, 2014 08:03 AM
Pewter442
38
Oct 5, 2014 11:35 AM
rmoths
Dec 5, 2012 06:50 PM
rmoths
Nov 13, 2012 08:09 AM
john71
Aug 1, 2010 10:22 AM
