Voltage Regulator Location '73 Delta 88
Old Jul 9, 2013 | 03:35 PM
motor's Avatar
Gonna replace the altenator on the convertible this weekend and the vr as well. Is the voltage regulator located on the firewall, inner apron or inside the altenator like the newer cars?
Thanks!
Old Jul 9, 2013 | 03:52 PM
oldspackrat's Avatar
Don't know for sure, but I believe it's in the upper center of the firewall. It should have a 4? wire black connector, a black square metal top & held in by 3 screws with 3/8" heads.
On second thought, it may be internally regulated?? I don't know when they made the switch, but I'm sure someone here will know.
Old Jul 9, 2013 | 04:33 PM
Sugar Bear's Avatar
If the plug on your alternator is square it is an external regulator. If the plug is rectangular it is an internal regulator. Hope this helps.
Old Jul 9, 2013 | 04:40 PM
A 1973 Delta 88 should have an internally regulated alternator - a 10SI to be exact. To verify, look at the connector on the alternator. The one on the left is a 10SI. The one on the right is the older style with an external regulator:
Old Jul 9, 2013 | 04:53 PM
Alternator plug with external regulator: | |
Alternator plug with internal regulator: — —
That being said, why do you want to change it? Charging problems?
Old Jul 9, 2013 | 05:21 PM
motor's Avatar
Thanks everyone,
The generator light is on and the altenator is old as dirt. Finally moving it from the driveway where it was rotting to my place. Got new (used) tires, a battery, fresh gas, fuel filter, air cleaner and PVC valve already. Gotta get it cross town to my place and the muffler shop.
My altenator has the internal regulator - thanks for the pics and advice. Gonna replace the belt as well. Easy on the older cars, everything is right up front.
Old Jul 9, 2013 | 05:31 PM
Did you check the voltage with the engine running?
Old Jul 15, 2013 | 05:35 PM
motor's Avatar
New alternator installed in 10 minutes. Full charging now.
Old Jul 15, 2013 | 06:41 PM
Great!
delta_88_germany
Feb 22, 2014 01:48 PM
Dave Siltman
Tech Editor's Desk
Mar 21, 2013 02:05 PM
ow30442
Sep 2, 2008 02:51 PM
rocket69
Aug 14, 2008 09:09 AM
and1stp
Sep 17, 2006 07:31 PM
