Tires - Bias Ply to Radial
Old Apr 7, 2010 | 04:30 PM
coltsneckbob's Avatar
Hi,
According to the options list for my 1970 442 it came with G-70 Bial Ply tires. It currently has BF Goodrich P215/70R14s on it. However, these radials are not over 11 years old.
I've not found a really good conversion chart on the Net, but based on what I've read I actually could probably put P225/70R14s on it. In fact if I am correct they are closer in diameter to the original G-70s then the P215s.
Can anyone confirm P225s are going to fit well on the car? I am certain I have plenty of room for turns in terms of chassis, and I think (though it is harder to judge) that I have plenty of room under fenders even on a hard turn.
Thanks!
Old Apr 7, 2010 | 04:57 PM
Thanks!
Assuming you're using the SSIII wheels in the photo (or some other wheel with stock offset) then the 225/70-14s will fit fine. These tires are about 26.5" in diameter with a section width just under 9". I've successfully run 255/60-15s at all four corners of several 68-72 A-bodies. My tires are about 1" wider and 0.5" taller than the ones you're asking about.
Old Apr 7, 2010 | 05:03 PM
stevengerard's Avatar
I have 235/60s on mine now and was thinking of going wider with the next set as well 245 or 255
Old Apr 7, 2010 | 05:31 PM
Thanks all.
Old Apr 7, 2010 | 05:39 PM
bigoldscruiser's Avatar
2 '66 98's
Where are you going to get this size tire???
Old Apr 7, 2010 | 07:47 PM
I don't know yet. My first stop will be Coker Tire.
Does anyone know if 235-70R14 will fit on the SSII wheel???
Old Apr 8, 2010 | 06:43 AM
Assuming it's a 14" SSII wheel... Yes.
Actually, a 14x7 would be preferred.
buddys442
Dec 31, 2013 06:57 AM
71DP
Wheels and Tires
Jun 7, 2013 09:20 PM
Octania
Wheels and Tires
May 13, 2012 08:39 AM
Geo88
Apr 7, 2011 10:13 PM
w-30dreamin
Wheels and Tires
Dec 31, 2010 08:49 AM
