Brake/Fuel Lines... OE Steel or Stainless Steel?
Old January 27th, 2010, 10:10 PM
oldzy's Avatar
My frame was recently powder coated (to be used on my 72 Cutlass Supreme) and I am going to install the fuel and brake lines first. A few questions...
1) Which do you prefer and why... OE steel or stainless steel?
2) Should I use my original steel Proportioning Valve, or get one of the new brass repro ones? I have rear drums and front power discs.
3) I removed the Carbon Canister long ago... which fuel lines do I need? Do I just use the main line? What about the return and vapor lines? I don't even recall 3 lines originally, but could be mistaken. I recall putting a rubber boot on the end of one of the lines under the hood when I removed the CC.
Thx
oldzy is offline
Old January 28th, 2010, 04:00 AM
70 cutlass s's Avatar
You can buy a role of stainless steel cheap. Than bend it the way you need it. Pretty easy. As far as how many fuel lines it depends on which fuel tank you have their are some that have 3 some that have 2 places for lines. One thing that is for sure that you need a vent whether it's a canister or the vent that mounts on the frame by the tank.
70 cutlass s is offline
Old January 28th, 2010, 04:19 AM
Oldsdruid
rocketraider's Avatar
Stainless will not rust, but it can be tricky to get a good seal at flare connections. If I had my time to do over, I'd have used OE steel lines on my Starfire instead of the stainless.
rocketraider is offline
Old January 28th, 2010, 05:14 AM
Lady72nRob71's Avatar
If the OE steel lasted 40 years under normal driving conditions, new OE steel will last probably 70+ years under "babied" conditions that most collector cars are given.
Lady72nRob71 is offline
Old January 28th, 2010, 09:46 AM
oldzy's Avatar
I am going to go the OE Steel route.
In re to the gas tank, I guess I screwed up back in high school as I plugged that vent hole under the hood. It was like that ever since. How is it properly vented near the gas tank? What does this 'vent' look like that mounts on the frame? I want to mount an electric fuel pump at some point also (not sure where the best place is for that yet on the frame).
Thx
oldzy is offline
Old January 29th, 2010, 12:11 PM
Why go through all the trouble to powdercoat the frame, just to use steel lines that will have a coating of rust in a few months. I use stainless.
joe_padavano is offline
Old January 29th, 2010, 04:12 PM
oldzy's Avatar
Darn, now I all confused. I went and ordered OE steel brake lines from inlinetube and here you be saying it will rust soon on my newly powdercoated frame. Oh well. The frame will will prob sit for years anyway before the body gets redone, so we shall see. I can always order the stainless if I don't like the OE.
On a related note, I have 4 somewhat bare spots where the frame sat while it was powder nosed. I hope I can 'paint' some Chassis Black paint on the spots.
oldzy is offline
Old January 29th, 2010, 04:15 PM
car guy
gearheads78's Avatar
The stainless looks much nicer but takes some effort to seal up.
gearheads78 is offline
Old January 29th, 2010, 05:53 PM
Land Yacht Captain
66ninetyeightls's Avatar
So just give the OE lines a good coat of paint before mounting it on the vehicle. Then once its mounted paint the parts you couldn't before assembly.
66ninetyeightls is offline
Old January 29th, 2010, 06:04 PM
Eastwood sells different shades of "raw steel" colored paint, if you wish to paint the lines before installing them.
Old January 29th, 2010, 06:06 PM
GM Enthusiast
OLD SKL 69's Avatar
On any of the cars that I have restored, I have used stainless gas and brake lines. I just figured that for the small amount of additional money, it was worth it. I never had a problem sealing up the lines either.
I do not think the steel lines will rust on the outside if you have it in the garage and out of the weather. And if you use silicone brake fluid, you don't have to worry about the brake lines rusting from the inside out. (Especially when these cars sit for a long time.) Something to consider, either way it will work out fine.
OLD SKL 69 is offline
defiant1
August 22nd, 2015 08:49 PM
76 Regency
April 20th, 2013 07:17 AM
1k442
December 3rd, 2012 11:20 AM
Eddie Hansen
April 30th, 2010 04:26 PM
phill_ratrodv8
September 15th, 2009 02:22 PM
Quick Reply: Brake/Fuel Lines... OE Steel or Stainless Steel?
