260 olds water pump
Old May 28, 2025 | 09:01 AM
abryan's Avatar
260 olds water pump
Hello ........Which water pump is better to use on a 260 olds...long or short?... Which water pump is best...Thank You...
Old May 29, 2025 | 04:39 AM
The "best" pump is the one that matches the pulleys and accessory brackets. Any deviation from that will cause the pulleys to be misaligned.
Old May 29, 2025 | 05:24 AM
BlueCalais79's Avatar
IMHO, the best water pump (w/p) would be the one you already have if it is original; if it croaked, remove it & send to a rebuilder, such as Arthur Gould Rebuilders, etc.
I bought a new aluminum GMB water pump to keep in my trunk as a spare in case mine goes bad while I am out on the road far from home (my package shelf space in the trunk is reserved for this, an Alternator, belts, hoses, a D1906 Ignition Module and of course tools to fix all this stuff if needed). But, if I can get the car home I would not hesitate to pull it and send the w/p out for a rebuild.
x2 on what Joe P advised on the pump's length, it's got to match your pulleys & brackets, or it's worthless.
My 79 H/O has a rebuilt w/p from Arthur Gould which was installed 3 years ago, no issues to date.
Old May 29, 2025 | 05:44 AM
Sugar Bear's Avatar
It isn't a question of "best" rather a question of correct or incorrect. As stated the wrong length will misalign the pulleys. Replace it with the length that is on it now.
Old May 29, 2025 | 10:51 AM
abryan's Avatar
Thank You...
vickycar
Aug 19, 2021 09:36 AM
Lars
Nov 10, 2013 12:05 PM
501Paratrooper
Jun 1, 2013 08:15 PM
J-(Chicago)
Mar 30, 2013 02:54 PM
Driftr
Oct 11, 2011 12:35 PM
