1971 Cutlass Grill
Old Oct 29, 2022 | 04:14 PM
Falkon's Avatar
1971 Cutlass Grill
What is the easiest way to remove the grill to be able to access mounting for the stone guard? I have seen 2 sections in the Chassis Manual, bumpers & front sheet metal, yet neither addresses how to accomplish removal. My car had front end damage prior to my purchase. Bumper was replaced, but some things still don't line up well. In addition to needing to adjust the bumper, the stone guard has too large a gap from the hood. The left grill is out 1/2" at the top, in the center.
Old Oct 29, 2022 | 04:19 PM
Falkon's Avatar
Old Oct 29, 2022 | 04:36 PM
It isn't much fun. Plan to remain on your back for some time. Negotiating, aligning the bumper is rather straight forward once you locate the nuts/bolts/brackets. I found using a hydraulic floor jack (w/ towels) works well for securing/holding/maneuvering the bumper into position.
Old Oct 29, 2022 | 04:47 PM
Falkon's Avatar
Thank you. Those are better than the pictures I found in my factory manual. I've read several posts about this subject & it sounds like we will need to loosen the bumper anyway. I'll get my son to assist. Thanks again for the pictures. Al
Old Oct 29, 2022 | 05:04 PM
The images are from the 1971 Oldsmobile Product Information Manual (PIM) a.k.a. & commonly referred to as the Factory Assembly Manual (FAM). You'll notice the name of the manual on the lower RH corner of the images.
The PIM is long out-of-print and good paper copies are difficult to come by (as are any digital versions). You can reach out to CO member Hairy Olds if you're interested in purchasing a PIM. He has the best copies available that I've seen.
Old Oct 30, 2022 | 05:15 AM
I found it easiest to remove all bumper bracket bolts except the 2 rearmost ones- loosen them and let bumper swing down watching wiring, etc. Then easier to get to grilles, etc.
solly
Jul 27, 2022 10:48 AM
78CutlassCalais
Jan 29, 2021 03:51 AM
OldsManNJ
Jul 3, 2011 06:14 AM
mhartley
Jan 24, 2011 11:39 AM
<Don P.>
Jan 27, 2005 07:25 AM
