67 Cutlass vin decoder
Old November 19th, 2017, 09:54 AM
brianbeez67's Avatar
Hey guys, I have a 67 C/S holiday coupe (few options). still trying to decode the cowl tag. I figure to start a thread and have your guys input.
First row
1. E-2 (soft ray glass)
2. K (Air conditioning)
X (Jetaway)
G (Console)
Second Row
1. 5 ( ????)
Y (Seat Belts)
P (????)
Any help with the 5 & Y would be great.
It had SS1 rims on it when I bought it back in 1987, single exhaust, manual windows, vinyl roof
brianbeez67 is offline
Old November 19th, 2017, 11:23 AM
First row
X (Jetaway)
G (Console)
Second Row
1. 5 ( ????)
Y (Seat Belts)
P (????)
So, first thing is, despite the title of your thread, that's not the VIN, that's the cowl tag (as you apparently already know from the body of the post). A VIN decoder isn't going to help.
Cowl tags of this vintage have up to five rows of accessory codes. The 1, 2, and 5 simply refer to the rows. The code letters following them mean different things depending on which row they show up in. For row 5, the "Y" means deluxe seat belts.
A photo of the cowl tag would help a lot. Is the "E-2" really on the lower left of the cowl tag where the accessory codes are, or is it on the right, next to PNT? If the latter, that is the paint code where E = Midnight Blue and 2 = black vinyl top.
joe_padavano is offline
Old November 19th, 2017, 11:34 AM
Cowl tag
will post pic of tag shortly
Old November 19th, 2017, 11:56 AM
67 C/S Cowl tag
67 C/S cowl tag 11 19 2017 cowl tag.PNG
Old November 19th, 2017, 11:59 AM
67 C/S cowl tag Attachment 198329
Any chance you can post the WHOLE cowl tag?
And yes, that's "E" for tinted glass and "2" to designate row 2.
Old November 19th, 2017, 01:07 PM
lemoldsnut's Avatar
yes as Joe stated a picture of the entire tag would help.
The E even though it is right next to the 2 is in the first row of what Joe had mentioned. The P is one that comes up now and then and there is some confusion as to what it represents.
So this is a Cutlass or Supreme and has a floor shifted ST300 trans and air conditioning. with deluxe seat belts. oh and black interior with bucket seats.
lemoldsnut is offline
Old November 21st, 2017, 07:43 AM
Run to Rund's Avatar
GROUP 1
E = Tinted glass - All - (A01)
W = Tinted glass - Windshield only - (A02)
0 = Roof moldings for two-tone paint - For (D99)
S = Power Trunk - (A 91)
T = Power Seat - Bucket for sure – (A46). Bench maybe – (A4I) (1965)
T = Vinyl top (unconfirmed) (1966)
L = Hole & mounting plate for floor shift manual (1966)
X = Power windows - (A31) (1965)
X = Column shift auto (1966)
F=power seat (1967)
GROUP 2
K = Air Conditioning - (C60) (E in 1967)
G = Console - (D55)
X = Floor mounted Automatic Transmission - used with (D55)
L = Floor 4spd - (M20 or M21)
B = Floor 3spd - (M12 or M14)
R = Rear Shelf Speaker - (U80)
T = Power Antenna - (U75)
A = Extra Foam Padding – Front Seat
P = Unconfirmed
H = Heater Delete (1966 only)
GROUP 3
D = Unconfirmed – only seen with interior accessory package.
W = Unconfirmed (1965)
W = Carpeting (F85 only) (1966)
B=rear defogger (1967)
GROUP 4
C = Chrome side window sill moldings – (B85)
H = Chrome upper “peak” body side moldings – (B84) (1965 only)
M = Moldings - door/window glass frame (F85 only) (1966)
V = 442 side trim – (W29) (1965)
D = Y68 side moldings
GROUP 5
F = Remote mirror (D33)
W = Deluxe front seat belts (A49)
Y = Deluxe front and rear seat belts (A39)
M = Unconfirmed
O = Unconfirmed – may be seatbelt delete (A62)
V = 442 trim (1966)
Z = Belts, shoulder harness (1966)
J=center rear seat belt (1967)
_________________
1966 Red-Fawn F-85 4-4-2 4-Speed
1966 Red-Black F-85 Deluxe L69 M21 (1/178)
Olds442L69 on realoldspower
[H belongs in Group 2]
From 66cutlass on ROP on 10/01/08:
B is the seat type
B---Strato Bucket Seat
P---Reclining Strato Bucket Seat
R---Reclining Strato Bucket Seat With Strato Headrest
S---Strato Bucket Seat with Strato Headrest
A---Conventional Bech Seat
E---Coventional Bench with Conventional Headrest
D---Strato Bench Seat
J---Reclining Strato Bench Seat
K---Reclining Strato Bench Seat With Strato Headrest
L--- Strato Bench Seat With Strato Headrest
This is out of a parts manual dated Sept 1966.
Run to Rund is offline
Old November 22nd, 2017, 12:34 PM
67C/S Cowl tag
Let me try to get back on track with the locations of the groups
going back to my original one-
1. is E-2 group 1, KXG group 2, 5YP group 4 or 5?
2. What does the 2 in E-2 mean?
3. KXG matches great
4. The "Y" matches your group 5 seat belts.
My other 67 Cutlass 2 spd column shift, bench seat with head rests, power antenna, vinyl top, numbers are
984-N
W 2XTR
5YP
Both share the "5YP"- trying to find out who else out there has the 5YP and what options do they have to help fill out/ correct when needed your very detailed list
The "X" does not work- column shift
The "T" works for power antenna
The "R" never checked ? will need to.
rambled on a bunch sorry. as always any help is a lot more than I have now, thanks Brian
Old November 22nd, 2017, 02:28 PM
Go back and read post #5.
The digits are the row number. The letters that come after the digit are in that row. The "1" for row 1 was always left off, so no leading digit = row 1
From the TINY fragment of the cowl tag that you've shared with us (is there some reason why you can't just post a photo of the entire tag?), we get:
Row 1 = E
Row 2 = K, X, and G
Row 3 = no codes
Row 4 = no codes
Row 5 = Y and P
joe_padavano
Tech Editor's Desk
25
July 6th, 2015 12:22 PM
gtdrvr
January 1st, 2012 08:08 AM
decodethis
December 17th, 2011 03:18 PM
Jamesbo
November 21st, 2008 04:34 PM
65 Dynamic 88
February 26th, 2008 04:57 PM
Quick Reply: 67 Cutlass vin decoder
