1972 Cutlass Supreme Vapor Canister
Old May 15, 2017 | 12:58 PM
Will22's Avatar
I see to be struggling to find a replacement vapor canister for my 1972 CS. Can someone point me in the right direction?
Old May 15, 2017 | 01:49 PM
oldspackrat's Avatar
Do you mean the plastic one with two nipples that sits behind the passenger side headlights? If so I have several of them. $25 shipped for 1.
Old May 15, 2017 | 02:45 PM
Will22's Avatar
Yes. Could you send me the height and diameter of the ones you have? Are the ones you have new?
Will
Old May 17, 2017 | 10:38 AM
oddball's Avatar
Service replacements are readily available. They're called "vapor canisters". The hookup is a little different - it uses stacked nipples and draws air from the top instead of the bottom. Standard Products CP1022 or ACDelco 215153.
Old ones can be fine - just sometimes the bag holding the charcoal falls apart and the car sucks down the dust. No bueno.
Old May 17, 2017 | 10:40 AM
Will22's Avatar
Thanks guys. I ordered the AC Delco 215-153. It seemed to be the closest fit for my mounting bracket.
Old May 17, 2017 | 07:38 PM
Well, I finally got around to getting pix today. Sorry for the slow response, lots of family stuff going on right now. This one came out of a '71-'72 Cutlass. I understand if I'm too late.
rc_bloom
Aug 10, 2017 04:19 AM
rhett838
Jul 24, 2015 12:23 AM
Redog
Nov 17, 2013 07:41 PM
oldzy
Dec 14, 2010 06:47 AM
ChefDeadpool
Dec 12, 2010 05:43 PM
