Air conditioner gasket/ weather stripping
Old March 2nd, 2017, 12:48 PM
NoahJoseph's Avatar
Does anyone know if there's a gasket, weather stripping, or something I can do to replace this nasty worn out "gasket" around the AC box, taking everything off of the firewall to clean and paint and would like to replace the stuff, thanks 1970 Cutlass Supreme
NoahJoseph is offline
Old March 2nd, 2017, 02:22 PM
oddball's Avatar
That's plain old rope caulk. Can be bought at hardware stores in the weatherstrip section, also used around windows. You have to remove the box from the firewall, clean up the firewall and box, and re-caulk in the recess in the box.
In case you haven't seen it before, it comes in boxes. It's caulk that is semi-rigid and in a string just wound up on itself. Not like silicone caulk in a tube.
oddball is offline
brent
October 3rd, 2011 07:47 AM
roomer
September 13th, 2011 05:14 AM
toms vista
Vista Cruiser & Wagons
August 27th, 2010 09:07 AM
KRICHEN922
Body work
March 27th, 2010 11:07 AM
yzzerdd
March 8th, 2010 05:11 AM
Quick Reply: Air conditioner gasket/ weather stripping
