Plugs from hell or All plugged up.
Old February 17th, 2017, 02:00 PM
Kraven Moorehead's Avatar
My son's Grandpa gave him a 69 442 "holiday edition" it uses the 455 fuel pump so I figured 455, right? Maybe, maybe not. The plugs I ordered do not fit. They are the the ones that take the 'fat' plug socket and have the compression seal washer (that sound right?). And ALL choices for that year were some iteration of the same 'fat plugs'. We pulled one out and it took the 'skinny' plug socket and had the taper or bevel fit and were, no kidding, 666 Autolites. My question is; Are the plugs from hell what came in it originally or was it the 'fatties'?
Kraven Moorehead is offline
Old February 17th, 2017, 04:18 PM
All 1964-1990 Oldsmobile V8 fuel pumps interchange, so that's no indication of engine size. Check the casting number behind the water pump, which will tell you exactly what engine it is. By the way, this one IS a 455.
joe_padavano is offline
Old February 17th, 2017, 08:24 PM
I've never known Olds engines to use the 5/8" "peanut plugs" - That's more of a Chebby thing.
The correct AC R45 or R46 crosses to an Autolite 306, 316, or 317.
The 666 crosses to an AC R43, 44, 45, or 46 TS plug, which is a tapered-seat plug with an extended tip, which is wrong.
Did this engine run?
Welcome to ClassicOlds.
ps: There is no such thing as a "Holiday Edition" Olds.
If the car has no center, or "B" pillar, then it is an Oldsmobile 442 Holiday Coupe.
Have you confirmed that the VIN begins with "34487"?
MDchanic is offline
Old February 17th, 2017, 08:33 PM
Another thought:
This IS an Olds engine, right?
MDchanic is offline
Old February 18th, 2017, 05:09 PM
Yeah, absolutely and it runs good. When Papaw says "it'll run", that translates to "it's a beast". The number requested by Joe Old(S) fart is 395558 which makes it a 73-74 350 but those are supposed to take the 'fat' plugs too. I guess I'll have to take a valve cover off as it appears the heads are a different animal. I am a Chevy man with a Pontiac fetish so Buick an Olds are uncharted territory for me, hence the membership to this board. I appreciate you and Joe's input on this. Thanks
Last edited by Kraven Moorehead; February 18th, 2017 at 05:13 PM. Reason: Forgot an item
Old February 18th, 2017, 05:18 PM
395558 is the casting number used on every single 350 block Olds cast from 1968 to 1976. The VIN derivative stamp below the no. 1 spark plug will tell you the exact year. The second character of the stamp is the year - 9=1969, 1=1971, etc. The casting number for the heads is located above the center two exhaust ports.
Old February 18th, 2017, 05:48 PM
Oh, okay, cool. I'll check all that and get back with y'all tomorrow. I'm gonna post a pic or two.
Old February 18th, 2017, 06:49 PM
Hmmmmm... The 442's got a 350.
Bet the first five digits of the VIN are not 34487.
The VIN derivative on the block is here:
Looking forward to seeing some pictures.
MDchanic is offline
Old February 19th, 2017, 05:49 PM
Oldsdruid
rocketraider's Avatar
Look on the heads, you'll find a number (SB) or letter (BB) cast into it at bottom left as you face the head. Some later heads used the taper seat 5/8" plugs.
rocketraider is offline
Old February 19th, 2017, 05:53 PM
You've apparently never worked on a 307 Olds...
(yeah, you're not missing much)
I just changed the 5/8" plugs on my wife's 1985 D88 today.
Old February 19th, 2017, 05:57 PM
Nope.
And I don't feel bad about it either.
Guess we've got an idea of what the OP's got under the hood now, anyway.
MDchanic is offline
Old February 20th, 2017, 08:30 AM
Right, Holiday coupe. (how queer is that?) no 'B' pillar. VIN starts with an ST69336. Going out now to take pics and look for numbers.
Old February 20th, 2017, 08:31 AM
The 307s actually used 5/8" plugs with gaskets, not taper seat. If that's what's on this car, the early 350 block has later heads.
Old February 20th, 2017, 08:33 AM
Standby, going out now for pics and number search
Old February 20th, 2017, 08:35 AM
That's not the VIN, that's the Fisher Body tag (aka "cowl tag"). The VIN is visible through the lower part of the windshield on the driver's side. This distinction is important on 1968-69 cars because Olds built real 442s with Cutlass cowl tags in those years. This is well documented, but often leads to confusion. The ST69 336... number is a Cutlass cowl tag. The VIN for a real 442 will start 344...
Old February 20th, 2017, 09:22 AM
Well, I guess it's just a Cutlass that somebody put the 442 badging on because that is the beginning of what is on the VIN tag at the windshield.
Old February 20th, 2017, 09:28 AM
Looks like a 34 under the #1 plug so 1974? Been in a barn for eons (hard to call it a barn "find" when we knew it was there) so we cleaned the tank and changed the sending unit first thing. That's why it's jacked up in the rear.
Pics.
Last edited by Kraven Moorehead; February 20th, 2017 at 09:30 AM. Reason: forgotten items
Old February 20th, 2017, 10:58 AM
You've managed to not take any pictures of anything we need to see.
The number or letter on the head is not "34." It is a single digit about 1" tall.
The VIN derivative is under the alternator.
The VIN is visible through the windshield, but no Olds VIN begins with S. It will begin with a 3.
Pictures will help.
MDchanic is offline
Old February 20th, 2017, 11:18 AM
Beat me to it.
Or, it's a "3A" which would be consistent with the later model heads and small plugs.
Specifically, here:
No but the COWL TAG definitely starts with ST69, as I noted above.
Old February 20th, 2017, 11:51 AM
Right again, I asked my boy for the number off the plate under the windshield and that's what I got. Shoulda done it myself. As an aside I sent him out to pull the starter off an OT vehicle and he came in with half of it. I was absolutely amazed. The plate is rusty and the 4th digit is indiscernible but I got 344_79. And I believe 3A is what is stamped on the machined surface of the block albeit not an inch high, more like 1/4" high.
Old February 20th, 2017, 01:57 PM
The VIN will be 344879.....
3 = Oldsmobile Division
44 = 442 model line
87 = Holiday Coupe
9 = 1969 model year
The next character will be a letter or number for the assembly plant.
The final six are the sequential build number.
It's a real 442, and not surprisingly the engine has been replaced at some point.
Old February 21st, 2017, 09:52 AM
307?
So, it's a 307? I wonder where Papaw got the idea that it would run? Maybe it's had work done. We'll know more when we get brakes and tires on it. Are those the original wheels?
Old February 21st, 2017, 10:03 AM
So, it's a 307?
No. Please go back and read all the posts above, specifically posts #6 and #19.
395558 block is a 1968-1976 350 block
3A heads are 1977-1980 350 heads
307s were not the only Olds motors to use small plugs, just an example of one.
You DO have a frankenmotor 350, however. I ASSUME those are 3A heads, since you said "34", which doesn't exist, but "4" can be mistaken for "A" under the grease and rust. This is why I suggested waaaay back in post #6 that you provide the head casting number located above the two center exhaust ports. Sorry to be blunt here, but trying to help you is like playing twenty questions. We've told you specifically what numbers to provide (preferably with photos) and you don't. Kinda hard to help under these conditions.
If those really are 3A heads, they have the large-ish 75 cc combustion chambers. If the short block is an older one with high compression pistons, this would not have been uncommon in the 1980s to lower the CR as a way to allow the car to run on low octane gas. As for the car being able to "run", I find most people who have never driven a real 1960s big block musclecar think any American car with a V8 is "fast". Depends on your point of reference.
Old February 21st, 2017, 11:27 AM
Rocket Renegade!
Well regardless of what engine it has, it looks like a solid basis for a build. A real 4-4-2 and with minimal rust to boot (looks like you'll need a new decklid though) -- thanks, Grandpa!
All you need now is to find a 455 to pop in there -- now that'll run!
BangScreech4-4-2 is offline
Old February 21st, 2017, 02:58 PM
Yeah blunt, I get it. It's okay man. I used to go through the same thing when I had to deal with the public. Be assured, I am trying. I looked for the casting numbers above the two center exhaust ports. there aren't any. And I thought we were going with 3A too.
"We've told you specifically what numbers to provide (preferably with photos) and you don't". If you look, there is a good picture of the left side of the block and as stated, there are no numbers in the location specified.
"I find most people who have never driven a real 1960s big block musclecar think any American car with a V8 is "fast". Depends on your point of reference".
You may be right. Papaw is getting old but he has had a lot of fast cars and bikes and has a short leg to prove it. He still has an old Chrysler with a Hemi that scared the living crap out of me back in the early 90's. I won't get back in it. Personally, I hope it (the 442) is more mild than wild because of who will be driving it. Thanks for your help. Sorry it was tough.
Old February 21st, 2017, 03:06 PM
The cylinder head casting number looks like this.
The photo you posted is too far away and at an angle that makes it impossible to see. Wire brush the rust off of that area. On 3A heads, that number will be 554716.
Old February 21st, 2017, 03:10 PM
I think the "Frankenmotor" is fine for now. As for the deck lid, I plan on welding in a piece of metal because what you see is all the rust there is on it (the deck lid). I'm gonna put some patch panels in the quarters and at the bottom of the fenders then put it in primer and let the big dog eat til baby boy saves up for a paint job. The only thing we are gonna change is the hood. Do you think those are the original wheels? Something makes me think they belong on a Buick.
Old February 21st, 2017, 03:11 PM
I'm goin out right now. gimme 15 and standby.
Yep, it was crudded upand blended with the rust. Looks like 411 929
Last edited by Kraven Moorehead; February 21st, 2017 at 03:24 PM. Reason: addendum
Old February 21st, 2017, 03:14 PM
BlackGold's Avatar
It's fine if you feel a frankenmotor is fine, but you still need to determine exactly what you have. Otherwise you'll forever be buying the wrong parts to maintain it -- parts like, ummm, sparkplugs.
BlackGold is offline
Old February 21st, 2017, 03:22 PM
oldolds88's Avatar
kraven moorehead lol love the name. I am too lol
oldolds88 is offline
Old February 21st, 2017, 03:24 PM
  #31
Those are SuperStock I wheels, also called Magnum 500 by other manufacturers. They were a $90.58 option on a 1969 442 (RPO PO5).
Old February 21st, 2017, 03:31 PM
  #32
Cool, we'll keep them then. those numbers (best I can tell) are 411 929
Old February 21st, 2017, 03:33 PM
  #33
411929 are the 1973-1976 350 heads. The large raised number near the no. 1 and no.8 plugs should be an "8". These heads came with R46S spark plugs, which are DEFINITELY the 13/16" hex plugs with a 14mm thread.
I'll also point out the 411929 heads, the 395558 block, and the intake with a cap over the EGR valve location are all consistent with a 1973-76 350 motor. I'll also note that the carb APPEARS to be the one for the original 400 motor, and in particular, it appears to be configured for the divorced choke used on that motor. Since the intake on this 350 was designed for a carb with an integral choke and does not have any provision for a divorced choke, I assume the choke is non-functional.
Old February 21st, 2017, 06:23 PM
  #34
So just to clarify, it's not a cobbled up motor. Block is 68-76 350 and heads are 73-76 so in all probability it is a 73-76 350?
"I assume the choke is non-functional".
right again, the choke is wired open. I was going to run a manual choke but the operating rod is inside the carb housing. To put it back original, I would have to locate the correct carb. I am thinking we would be money ahead to just buy an Edelbrock with an electric choke and be done. Any ideas on the correct CFM?
Old February 21st, 2017, 07:34 PM
  #35
Many options here. You could get a QJet with an integrated choke to put on the existing intake or you could get a '69 350 intake manifold and the original carb and choke would bolt right up.
Fun71 is offline
Old February 21st, 2017, 10:02 PM
  #36
... the carb APPEARS to be the one for the original 400 motor, and in particular, it appears to be configured for the divorced choke used on that motor.
You would think so, but it's got a right angle fuel inlet, so it can't be a '69 Olds carb.
Also, I would like to re-emphasize what Joe said: The 350 heads were not made for the peanut plugs.
They were made for washer-sealed square seats, and not for tapered seats.
You need to look into this further.
Because of this confusion, you should also confirm the big series numbers on the heads: as noted, on each head, to the left of the leftmost spark plug hole (#1 on the left side, #8 on the right), there should be a 1" high "8" or "3A" (or maybe something else). You really can't miss it.
MDchanic is offline
Old February 22nd, 2017, 09:53 AM
  #37
Good point. I wasn't paying attention to that. It looks fairly new, so it must be a generic Chebby replacement.
The stock plugs used a 14mm thread, gasket seat, and 13/16" hex. The AC Delco numbering system decodes R46S as follows:
R = Resistor Plug
4 = 14 mm thread size
6 = heat range
S = extended tip
Note that the default is gasket seat. There would be a "T" suffix for a taper seat plug.
You can also get 14mm gasket seat plugs with a 5/8" hex. As I pointed out above, that's what the 307s use. Not correct for this 350, but they WILL thread in and work.
Not really. He was given the wrong plugs by a clueless parts counter worker.
The 411929 casting number is plenty of proof. There aren't a lot of Olds heads with casting numbers that start with 41xxxx anyway, so it is unlikely that these are something else.
Old February 22nd, 2017, 10:13 AM
  #38
This thread's already getting long enough to test your memory.
The parts guy gave him the correct plugs (based on the head casting number) - the plugs that were there already were the wrong plugs.
MDchanic is offline
Old February 22nd, 2017, 10:16 AM
  #39
Doesn't take much to do that these days...
Techincally, the parts guy likely gave him the correct plugs for a 1969 G-block, but yeah, they would have been closer to correct.
So apparently someone had previously installed the INCORRECT taper-seat plugs. How about a close up photo of one of the plug hole with the plug removed? (Preferably well lit and in focus so we can see the actual seat?)
Old February 22nd, 2017, 10:26 AM
  #40
Well, here's my take on this whole thing. The correct plugs for the original engine in a 1969 442 (the G-block 400) would have been R44S, which are 14mm thread, gasket seat, 13/16 hex.
SOMEONE in the past incorrectly installed R44TS (or equivalent), which are 14mm thread, taper seat, 5/8 hex. Hopefully this has not damaged the seats in the heads.
Again, the correct plugs for a 1973-76 350 motor would be R46S, or equivalent, also 14mm, gasket seat, 13/16 hex.
Quick Reply: Plugs from hell or All plugged up.
