AC hoses
Old Oct 4, 2016 | 03:51 PM
My2nd 69 442's Avatar
AC hoses
Hi guys
I'm looking to replace the AC hoses on my 442. Hoping some of you can help me out on where to find the most original looking hoses for the best price.
Jerry s
Old Oct 4, 2016 | 06:25 PM
oldspackrat's Avatar
I have some original nice looking hoses here in Indy. I'd like to get $35.00 each plus shipping. I can get pix if you want?
Old Oct 4, 2016 | 07:26 PM
Please do pm me pics
Old Oct 5, 2016 | 05:50 AM
rob1960's Avatar
Jerry, if you're going to use the newer R134a in your system in place of the original R12 you should get a modern set of hoses. They have a "barrier" lining in them that works with R134a(they work with the original R12 also). The R134a will eventually break down the original hoses on the inside & they'll start to leak. Someone had converted my '68 to 134a before I bought it & it still had the original lines on it. It worked but after running the a/c for a summer the discharge line off the compressor would weep fluid. I went ahead & replaced all 3 lines with a set from classic auto air. They were a little pricey at $350 plus shipping but they look & fit well. The crimping on the fittings doesn't quite look like the originals(they have more "ribs" than the factory crimps)but the discharge line has the 1 piece factory style foam sleeve on the muffler that the earlier repops didn't have. Make sure you replace the filter/drier with a new one while your system is apart.
Old Oct 5, 2016 | 10:43 AM
I want to continue with R12. I have a 30 lb. can of R12. That will be a life time supply for me.
Old Oct 5, 2016 | 02:33 PM
If possible l would like to find hoses and a dryer that will pass muster of OCA judged events.
Old Oct 6, 2016 | 06:15 PM
Does anyone have experience with "oldairproducts"
I'm having a tough time finding all 3 AC hoses and Dryer that are NOS or at least a good
aftermarket representation of NOS.
Any help or ideas on where to find the hoses will be greatly appreciated.
Old Oct 6, 2016 | 06:57 PM
Here are 3 nice looking ones I grabbed off the shelf. With some clean up they will be even nicer but I don't know if I would call them excellent.
Old Oct 6, 2016 | 07:42 PM
My only concern with buying used is finding the same issue I have with my original hoses is finding that they may leak where mine leak where the ends are crimped on the hoses. My hoses look great but with a "sniff " when we serviced it we found the leaks discribed.
Does anyone know if the ends can be re-s wedged?
Old Oct 10, 2016 | 12:11 PM
oddball's Avatar
Sure, but I wouldn't be surprised if a shop refused to do it with the old hose. Either it was made poorly, or the hose has deteriorated. Installing a new crimp may not address either issue.
Getting a 100 points installation - that also works - is a tall order. I would be especially suspicious of any NOS drier.
packrat, do you know what years used the inline muffler? My '72 came from the factory with the compressor-mounted muffler but of course only the inline muffler is repoped. My assumption was the inline muffler was 68(ish??)-72(ish??) then switched to the compressor mount in '72?
Old Oct 10, 2016 | 02:08 PM
Oddball
I'm finding exactly what you just posted to be very true. When I had my system serviced about 2 months ago we found the hoses leaking at the couplings. Held good cooling until about a week ago. Now no cooling at all. I could probably add another lb of R12 but it's gonna keep leaking so I want to fix it right.
My desire to keep as stock as possible is due to car scoring 983 in the North Texas OCA show this past April before I bought it.
Fixing one thing at a time is getting expensive.
Old Oct 10, 2016 | 04:33 PM
I might be wrong but I think the compressor mounted muffler was introduced in '72 like you said. I believe the inline was '68-'71.
Old Oct 10, 2016 | 06:22 PM
I can tell you that my 69 442 has the muffler in line. The others I can't say.
Old Oct 10, 2016 | 08:12 PM
My '71 is compressor mounted.
Oldssupreme
Sep 20, 2016 07:48 AM
Iragh
Nov 17, 2008 03:41 PM
relic
Feb 23, 2008 04:43 AM
Redog
Dec 29, 2007 09:13 AM
dynamic371
Mar 1, 2007 12:57 PM
