Wiper Motor Smoke- 69 Hurst
Old May 10, 2022 | 11:11 AM
jklmmorr's Avatar
In my 69 Hurst the washer pump quit working. I pulled it part and found the arm was not properly engaging when activated by the magnet. I cleaned that area a little, tested with the battery. I re-attached it to the wiper motor, and it now works. However, when the wiper motor is on high speed, smoke comes out of the plastic around the washer pump. At low speed it does not appear to be making any smoke. Any thoughts on why it might be smoking on high speed and not low? I think the smoke is coming from the wiper motor gear area rather than the washer pump. I just got the car so I don't know how long it has been since the wipers were used. The washer bottle had a hole in it and now pick up hoe, so imagine it has been a while since the washer and probably the wipers have been used.
Jay
Old May 10, 2022 | 03:51 PM
Generally, all electric/electronic parts are made with varying amounts of smoke. When the part lets the smoke out it's no good anymore. With that said, for some reason the motor or something in the wiper assy is getting hot. Look for binding or areas overheating.
Old May 11, 2022 | 02:31 AM
Old May 11, 2022 | 05:50 AM
jklmmorr's Avatar
Lord Lucas-Prince of Darkness
Old May 11, 2022 | 05:51 AM
jklmmorr's Avatar
I'll have another look and watch it closely.
thanks,
The Bug Man
Jul 5, 2016 12:57 PM
ioldsnut
Dec 12, 2015 06:27 PM
car_designer
Jul 8, 2013 03:31 AM
64Todd
Apr 14, 2010 11:01 AM
car_designer
May 10, 2009 10:26 AM
