Where to Install Second Coolant Temp Sensor for EFI
I am getting ready to install a Sniper EFI system on my 69 442 and need to know where I should connect the coolant temp sensor for the EFI system? The stock location has a TPS that is providing the gauge signal. Does anyone have advice on the subject?
thanks
thanks
Since your going EFI, you won’t need any of the thermal vacuum switches that originally screwed into the intake manifold. Leave the sensor for the factory gauge or light, put the EFI temp sensor in one of the unused coolant bungs.
