What is this?
Old November 18th, 2016, 02:27 AM
Goldenhand's Avatar
What is this?
Hello everybody!
I'm from Sweden and just bought my first oldsmobile😀.
A 1976 455 Cutlass Salon.
I'm stoked about it and will make some changes in the future.
Increase power, nas/stockcar paint and build a scoop on it.
It runs kind of bad know and i'm checking the vacuum wich seems to be bad on several places.
I run into this object and I can't find out what it is.
I'll be happy if someone can help me.
It's the grey thing located at right front side.
Regards. Mattias
Goldenhand is offline
Old November 18th, 2016, 02:57 AM
svnt442's Avatar
Given the location on the inner fender it looks aftermarket to me. It almost looks like part of a cruise control, but it's in the wrong placement for what it looks like to me. Do you have any other pictures of it?
svnt442 is offline
Old November 18th, 2016, 03:26 AM
Goldenhand's Avatar
No, not yet!
I'm on vacation and will be back soon and can take some moore pictures.
Old November 18th, 2016, 03:57 AM
mister442's Avatar
What is this
It is a factory option for rear air shocks that is a vacuum operated air compressor, There should be a dial under the dash to adjust the amount of air in the rear air shocks if the car still has them.
mister442 is offline
Old November 18th, 2016, 04:52 AM
Goldenhand's Avatar
Oh!
Thanks.
I have the switch under the dash but it seems not to work but now I know what it is.
Thanks so much.
Old November 18th, 2016, 04:55 AM
svnt442's Avatar
Never knew about that.
Originally Posted by Goldenhand
Oh!
Thanks.
Thanks so much.
You can see where a vacuum line attaches to it.
svnt442 is offline
Old November 18th, 2016, 05:19 AM
mister442's Avatar
What is this
Yes the engine vacuum line goes to the port on top and at the small end the air shock line goes to one port on the dash control and the second port goes to the air shocks. The engine vacuum line gets spliced to the p.c.v. line.
Old November 18th, 2016, 06:11 AM
Goldenhand's Avatar
Great!
Thanks.
Old November 18th, 2016, 07:07 AM
That is actually a vacuum-operated compressor for air shocks. A version of that was factory available in some years. I'm not sure about 1976. There was also an aftermarket version called JacPac offered by Delco at the dealer parts counter, which is what this one looks like. As noted, these came with an under dash gauge and control that looks like this:
joe_padavano is offline
Old November 18th, 2016, 07:13 AM
Goldenhand's Avatar
Thanks!
Great info.
Old November 18th, 2016, 07:30 AM
damaged442's Avatar
Great information!
Definitely don't see too many of those, that's for sure!
damaged442 is offline
