Water Pump for my 66 442 with A/C
Old February 17th, 2017, 01:31 PM
wmlewis's Avatar
Can anyone help to locate a water pump for my 400 engine with A/C.
I've gotten water pumps at the local parts houses but when they come in they are only 5" tall. I need to order a pump that is approx 5-1/2" or 5-9/16" tall but all the parts houses don't list the units by the height, and also be the heavy duty impeller.
wmlewis is offline
Old February 17th, 2017, 01:35 PM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
Try Fusicks or Year One. You could send yours out for a rebuild too if it's a date coded pump and that matters to you for originality?
droldsmorland is offline
Old February 17th, 2017, 01:39 PM
wmlewis's Avatar
I do not need a correct water pump casting numbers such.. Just a water pump that will do the job.
wmlewis is offline
Old February 17th, 2017, 01:44 PM
wmlewis's Avatar
Just checked Fussick lists pumps 71-? and Year One is just about the same.
wmlewis is offline
Old February 17th, 2017, 04:34 PM
Well, your problem is that the factory water pump for your car is P/N 388183, which is the 5.09" tall pump. I verified that P/N in the factory parts book. Has your engine been swapped at some point?
This site has the info you need to select a pump that will work.
It looks like you want P/N 230337, which is the 5.57" tall pump from a 1968-69 400 motor with A/C. One aftermarket version of that pump is Airtex AW926, about $56 at RockAuto.
joe_padavano is offline
Old February 17th, 2017, 06:10 PM
brandon reynolds's Avatar
I have a nice 384786 core its 5.09 tall with the factory cat impeller. $100
Correct for 65-67 330 and 400
brandon reynolds is offline
Old February 17th, 2017, 06:13 PM
66-3X2 442's Avatar
Most new pumps have the stamped impeller and you really need the OEM cast unit. I would find a good core and send it to a rebuilder for best results.
66-3X2 442 is online now
Old February 17th, 2017, 06:44 PM
Except that his old pump is the incorrect 5.57", which means his pulleys and/or brackets won't work with the correct 5.09" pump.
Old February 18th, 2017, 04:53 PM
Chesrown 67 OAI's Avatar
GMB makes an aluminum pump that is 5.5, as well as a 6.0, but does NOT make an aluminum 5.0 one. Rock auto has them. You gotta "back door it" by entering the part number found somewhere else. Rock has them - they just dont show up in their catalog search!! Ugh! Joe P knows exactly what i mean!! Hint -- go to summit and find the GMB number -- then take that number to Rock Auto part number search and it will pop up! It may be 130 - 1360? cant rmember for sure. I do know that the 130-1260 is the 6" hub height -- thats the one i use on my 67 400 so i can use the small diameter water pump pulley set from a 73 350 .
Chesrown 67 OAI is offline
Old February 18th, 2017, 04:58 PM
YUP -- found it for you at Summitt --- heres the link -- 5.57 hub height in aluminum GMB 130-1360
https://www.summitracing.com/parts/gmb-130-1360
Old February 18th, 2017, 05:03 PM
YUP -- Here it is at Rock Auto --- and only 30 bux too!! Summit was 56.00!
Glad to have helped.. Traveled this road before -- so this bridge is built for you, my Olds friend!!
http://www.rockauto.com/en/partsearc...num=130+-+1360
Old February 20th, 2017, 11:10 AM
wmlewis's Avatar
Thank everyone for your responses.. From what you sent me I will be checking them all out and I will let you know what I come up with... Bill
wmlewis is offline
Old February 20th, 2017, 11:28 AM
wmlewis's Avatar
Yaaah!! It looks like my seaqrch is over That should do it nicely and a decent price also.. Thanks for your help.. Bill
wmlewis is offline
joesw31
September 15th, 2022 09:31 AM
ROCKET VAPOR
September 19th, 2012 08:08 AM
Nor Cal Andy
March 29th, 2012 07:27 PM
brandon reynolds
March 5th, 2012 03:51 AM
72Ctlss
June 23rd, 2009 03:12 PM
Quick Reply: Water Pump for my 66 442 with A/C
