Ventilation
![Cool](https://classicoldsmobile.com/forums/images/icons/icon6.gif)
I've got a '74 Omega, 350/350 with factory A/C.
When the ignition is on, the HVAC fan/blower is on; on low but always on. Don't like that. Is there any way to rewire it so the fan doesn't come on unless I turn the fan on with the switch?
Next problem. The fan/blower switch has 4 settings, low, medium, high and extra high. The extra high doesn't work in either heat or A/C setting. I've tried changing a few obvious parts but it still doesn't work. Is this a common problem? Any suggestions or troubleshooting directions?
One more related problem. Fresh air. In the VENT mode, the air that comes in is hot even when it is relatively cool outside. Vent air is only cool when it's really cold outside. The air coming in doesn't smell like it's coming from the engine compartment but it sure feels like it. Haven't been able to find a drawing or diagram of the ventilation system. Where does the 'fresh' air come from??
DenverDutch
p.s. Thanks Joe, for the info on disc brakes.
DenverDutch
The HIGH setting sends power to the HIGH FAN relay in the engine compartment, which switches the supply from the dashboard switch through the resistor block to a supply from the horn relay terminal screw, through a 30A inline fuse, directly to the blower.
Steps to check:
- Switch ignition ON (engine OFF)
- Switch fan from #3 to #4 (HIGH) positions. Listen carefully for the tiny click of the relay inside the engine compartment. If you hear the click, you know that the circuit is good through the relay, which is to say the fan speed switch is good.
- Follow the heavy wire from the HIGH FAN relay to the horn relay. Find the inline fuse. Check it and clean contacts. Recheck.
- Check the continuity of the relay when in the HIGH position.
Go find it.
