Toronado Manifolds on a Delta?
Old May 16, 2015 | 07:16 PM
Blue65Delta's Avatar
I have a 65 Delta 88 2-door with a 425. I'm planning to go with dual exhausts. I have a chance to get a set of dual exhaust manifolds from a 66 Toronado with a 425. Will they fit on my Delta?
Old May 16, 2015 | 07:31 PM
2blu442's Avatar
No, I believe the toro manifold outlets will be too close to the firewall to work. I've heard of people using a pair of A manifolds, the one that was factory on the drivers side on both sides. You can also block off the crossover on your pass manifold, then run a pipe back from the drivers side. That's how all the small block dual exhaust cars from the late 1960's into 1970's were setup.
John
Old May 16, 2015 | 07:38 PM
Not even close. On the 1965-1970 full size cars, you MUST use the correct dual exhaust manifold for the driver's side. That's the only thing that will clear the steering box and shift linkage. Repros are available.
I was afraid there would be a clearance issue. Thanks for the info and the suggestions!
Old May 16, 2015 | 07:40 PM
Octania's Avatar
you need the LH "S" manifold. check Amazon.
Old May 17, 2015 | 12:06 AM
How is there a clearance issue when you use the correct factory dual exhaust manifold for this car?
Old May 17, 2015 | 11:23 AM
I was replying to the previous post when you posted yours. I was referring to a clearance issue with the Toro manifolds.
Old May 17, 2015 | 09:59 PM
Got it. Now I see the time stamps on the posts.
dlinderm
Jun 17, 2011 11:05 PM
j_link
Feb 11, 2011 10:01 AM
buickfarmer
Dec 12, 2009 10:18 PM
mutt
Jun 11, 2009 02:47 PM
jensenracing77
May 15, 2009 06:11 PM
