timing trouble '71 455
Can anyone explain why I need 35 + degrees initial timing to run. I checked timing mark to tdc,and cam timing marks.New MSD ready to run dist. checked with advance type light.I cant seem to find "sweet spot" Any help and or advice would be greatly appreciated
I second that. If the timing is off, get a new balancer. It will keep on slipping, and you will NEVER be able to set the timing correctly
jensenracing77
August 18th, 2012 08:06 PM
