Timing chain replacement questions
Thanks for taking time to read this. I'm going through a 1973 455cid before placing it in my 1969 Cutlass. What tools will I need to remove pulley, balancer, and get at the timing chain, and to replace the oil seal, and replace those parts?
thank you!
thank you!
A steering wheel puller works as a harmonic balancer puller. You'll also want a balancer installer so you don't have to beat it back on with a hammer. If the engine is out of the car, you can hold the flexplate while loosening and tightening the balancer bolt. A large socket or piece of pipe is all you need to get the seal in and out.
Yes, any harmonic balancer puller should be fine - as Joe said, you can get away with a steering wheel puller, or you can "free rent" a puller from your local chain auto parts store.
With the engine out, it's actually an easy job - the hard part is in cleaning up and repainting all of the parts before you put it back together.
Be sure to use a good quality replacement timing set (no $19.95 Chinese crap), and, if at all possible, to degree the cam before you put it back together.
Also, take a picture of it before you reassemble, for when you wake up in the middle of the night thinking, "Did I line up the dots right?!?").
"Also, take a picture of it before you reassemble, for when you wake up in the middle of the night thinking, "Did I line up the dots right?!?")."
AGREED.
Digital photos are almost free.
Take a few, from different angles.
AGREED.
Be sure the timing marks on the timing chain gears are aligned as shown in the CSM.
Fuel pump has to come out - don't forget the fuel pump eccentric on the cam gear and the oil slinger on the crank.
The other issue is when you remove/replace the timing cover. You have to drop the oil pan about 1/2 inch to get it out and in.
My suggestion would be to replace the oil pump, pick up, and oil pan gasket as well. It is a lot easier when the engine is out of the car.
(Not that I'D ever do that...)
As an example of how I may or may not have succumbed to the MAWs, on a running 350 that I recently had out of a car, I not only did everything noted above, but also replaced the rear main seal with a neoprene one, checked all bearing clearances with plastigauge (while showing uncharacteristic restraint by NOT replacing them), and replaced the valve seals by using an air fitting in the spark plug holes. I'll suggest that if the freeze plugs look at all questionable, there will never be a better time to replace them than now.
dewcrazzy
Oct 1, 2015 11:09 AM
