Tachometer question
Old Jan 30, 2010 | 10:38 PM
patmills's Avatar
442forsure
Tachometer question
On my '66 442, the tach is mounted externally on the left side of the dash.
I haven't been able to find out from my manuals whether it is mechanical or electronic. Could someone tell me which it is?
Thanks for your help.
Pat
Old Jan 31, 2010 | 12:01 AM
svnt442's Avatar
Unless there is a cable going from the distributor to the back of the tach it's electronic.
The only stock car I personally know of that used a cable (jones drive I believe it's called) it the Corvette and I think that even changed in 68, but I could be off on the year.
Old Jan 31, 2010 | 07:21 AM
wmachine's Avatar
Trying to remember member
Definitely electronic.
Old Jan 31, 2010 | 09:08 AM
As noted, a mechanical tach requires a cable like a speedo cable that is usually driven from the distributor. Olds never used such a system from the factory and frankly you'd be hard pressed to find an aftermarket tach drive distributor for an Olds.
Old Feb 1, 2010 | 06:38 AM
alexrains's Avatar
@pat: i have the same and posted a similar question, which was answered very fast; plus you can see a picture of that tach from the pcb side:
https://classicoldsmobile.com/forums...highlight=tach
Old Feb 1, 2010 | 04:24 PM
patmills's Avatar
442forsure
Tachometer
Thanks Alex. If I had just read my shop manual more thoroughly, I wouldn't have asked this question. I've located a little shop in Portland which restores instruments and he is going to put a solid state setup in my tach. Mine is working sporadically and the rpm it shows doesn't match with the sound of the engine.
Pat Mills
Old Feb 1, 2010 | 04:47 PM
svnt442's Avatar
Check it with a test meter to find out just how far off it is.
70cutlasssupreme
Jan 24, 2022 02:30 PM
toro455
May 9, 2017 08:07 PM
mryoung4815
Dec 14, 2013 09:38 AM
wazoo
Hurst/Olds
Aug 27, 2009 01:36 PM
Florent.turbo
Sep 10, 2008 01:10 PM
