Sun Distributor Tester
the 400-series were lower end units, it lacked the condenser tester unit. the differences in the 400-series model numbers relate to the era it was made in and the max. rpm it would spin. they were also known as the S.D.T. series.
example: http://www.ebay.com/itm/Sun-Distribu...item2a2c592b76
the 500-series were the deluxe models which included the condenser tester. same thing about the max. rpm and era as the 400-series. also known as the M.D.T. series.
example: http://www.ebay.com/itm/SUN-DISTRIBU...8821d3&vxp=mtr
generally, the higher the last digit in the model number, the higher the max rpm was.
bill
bill
Thanks Bill. Would either series be good for working with a 1970 + distributor? The rpm they spin at (sorry - at which they spin) is 1/2 the equivalent engine rpm correct?
Great idea... if you don't need a super pretty one, there are some on epay for more like 500-600
http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
Hairy Olds
February 10th, 2020 06:34 PM
chris83
August 18th, 2012 01:47 PM
