Steering column question
Old Feb 6, 2020 | 10:20 PM
dfire25's Avatar
"Trying to fix her right"
Hello everyone,
I am looking for a replacement “sponge” that goes on the end of the shift tube on a 71. Does anyone know if these are reproduced or available anywhere?
Thanks!
Old Feb 7, 2020 | 10:30 AM
70Post's Avatar
You could probably make one using some black closed cell foam sheet of the appropriate thickness. Since there isn't a "name" assigned to that piece in the diagram you show, it's probably not a part with a PN assigned to it or available from GM, "back in the day", separately.
I believe one "problem" is the seal/sponge was slipped over that end of the tube BEFORE the shifter ear/arm was spot welded in place. Why do I say that? Because the shift tube OD is larger ABOVE the foam seal (has a "step up" in OD above the foam seal/sponge) and again, no designation as a separate defined part in the diagram you show. Plus - each end of the foam seal has a black plastic "washer" that was attached to the foam and this would have prevented stretching when new (so it couldn't be slipped on from "above" where the tube diameter is larger).
Here's a pic of what appears to be a NOS shift tube with the seal in place. BUT....any of this type of foam is going to be well deteriorated as old as it is. The foam seal on this one has shrunk down and who knows how long before it begins to crumble like this foam will do over time.
Make your own using new materials. Cut a sheet and glue the ends together with a high quality superglue type adhesive. There is a black sheet plastic type material on each end of the foam sleeve - that was glue or somehow attached to the foam from what I can tell. Probably not necessary.
I'd probably try 3/8" sheet foam for thickness instead of 1/4".....a "rough" measurement of the foam on this tube shows it to be more than 1/4" thick and I can almost guarantee that it's shrunk up some as well.
Old Feb 7, 2020 | 01:43 PM
dfire25's Avatar
Thanks for the advise Patton. I figured I would have to make something since as you said, there is no part number or line item in the parts breakdown. Just was wondering if anyone has run into the same thing.
Old Feb 8, 2020 | 01:59 PM
Wow, I never even knew that foam was there! dfire, love your signature, funny I brought out a old Steve Earle CD and have been listening to it a lot the last week or so. I especially love "a week of living dangerously"- good stuff!!
Old Feb 8, 2020 | 04:48 PM
mrolds69's Avatar
They are re-proed, I've used them. I bought them before, I think it's actually a 2 piece set, like an upper and lower. I'll see if I can find who I got them from.
Old Feb 8, 2020 | 06:27 PM
dfire25's Avatar
Yeah I’m a big fan of Steve Earle too. I’m glad someone caught my quote. 😁
Old Feb 8, 2020 | 06:28 PM
dfire25's Avatar
That would be great, thank you!
Old Feb 8, 2020 | 07:23 PM
mrolds69's Avatar
I think these are the ones I used and they worked great! Very inexpensive, I can't recall if I just used the one seal, or what. I'm not home to check the number, but I'm sure this was the company. A LOT of peeps don't know about these. Don't tell!!! Patton, did you get my NOS hook fan pics?
https://www.detroitmuscletechnologie...end-foam-seal/
Old Feb 8, 2020 | 08:33 PM
dfire25's Avatar
Awesome! Thank you!
Old Feb 13, 2020 | 09:21 PM
dfire25's Avatar
Many thanks to mrolds69 for the info on where to buy the replacement “sponge” for the steering column shaft. The link is the one I ended up using. It was a little tight, but if you slowly work it it goes on ok. The large one in the double pack was too big, and the small one way too small. The single one fit just right 😁.
Old Feb 14, 2020 | 03:25 PM
mrolds69's Avatar
You're welcome! I could not remember which exact one I used, I think it was for Jeep. But it was from that company, before they would list on ebay. Glad it worked for you.
jozw30
Jan 20, 2020 01:25 PM
shockrebuild
Jun 10, 2018 04:38 AM
Aceshigh
May 9, 2016 04:18 PM
1966 442
Apr 26, 2015 08:30 PM
webby
Nov 30, 2012 06:52 AM
